crankshaft id
From st.clair shores,michigan.
how can you tell the difference if you have a A12 and A14 crankshafts side to side
Posted on: 2004/1/18 2:05
Remember When the chips are down the Buffalo is empty
Re: crankshaft id
Is there an "H" number stamped on each? The A12 parts are usually H10 or thereabouts. H62 would be an A14.
Posted on: 2004/1/18 4:33
Re: crankshaft id
From Stone Age somewhere in U.S.A.
actually if I remember my PNC's (part number codes) correctly it's H10=A12, H62=A13, and H72=A14. I could be wrong on this, it's been a few years.
Posted on: 2004/1/18 6:51
Re: crankshaft id
You're probably right. The part number codes refer to the chassis the part was first used in, so they vary. For example, not all B110 parts start with H10.
Posted on: 2004/1/18 8:30
