Re: Which thrust bearing carrier? (60a 5speed into 120y)
The strange thing is if the thrust bearing isn't coming close to the fingers on the pressure plate there is normally enough adjusment on the sleeve on the perch to gain some extra cable to ensure it (the thrust bearing) does engage. So it's really weird to hear that the adjustment cannot recuperate the 'extra'.
Posted on: 2011/1/20 7:57
Subject Poster Date
     Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2010/11/7 1:00
       Re: Which thrust bearing carrier? b310gx 2010/11/7 4:41
         Re: Which thrust bearing carrier? Weekend1000 2010/11/8 12:53
           Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/18 14:11
             Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/18 21:26
       Re: Which thrust bearing carrier? SunnyDaze 2010/11/9 10:27
         Re: Which thrust bearing carrier? SunnyDaze 2011/1/9 8:38
       Re: Which thrust bearing carrier? Anonymous 2010/11/9 10:30
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/9 9:39
         Re: Which thrust bearing carrier? (60a 5speed into 120y) ddgonzal 2011/1/9 21:19
           Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/9 22:13
             Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/9 22:25
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/19 10:44
         Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/19 10:50
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/19 11:01
       Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/19 11:26
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/19 11:37
       Re: Which thrust bearing carrier? (60a 5speed into 120y) Anonymous 2011/1/19 12:14
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/19 12:19
         Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/19 20:25
         Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/19 21:25
           Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/19 21:43
             Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/19 22:09
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/20 4:56
         Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/20 5:01
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/20 7:36
         Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/20 7:53
           Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/20 7:57
           Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/20 7:58
       Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/20 8:13
         Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/20 8:18
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/20 11:02
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/21 9:18
       Re: Which thrust bearing carrier? (60a 5speed into 120y) b310gx 2011/1/21 9:50
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/21 9:52
       Re: Which thrust bearing carrier? (60a 5speed into 120y) b310gx 2011/1/21 10:20
       Re: Which thrust bearing carrier? (60a 5speed into 120y) ddgonzal 2011/1/23 2:07
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/26 9:16
