Browsing this Thread:
1 Anonymous Users
Will an A15 head work on an A14 block? |
Quite a regular
From Brooklyn, NY.
Hi, I picked up an A15 head to use on my A14 engine and I was wondering if there would be any clearance problems, since the A15 pistons looked like they were a little more concave on top than the ones in my A14. Also, can anyone tell me about how much I should have milled off of the head to raise the compression a bit? I remember seeing this discussed on the site before, but I can't find the posts.
Will Krause
Posted on: 2004/1/23 6:09
Re: Will an A15 head work on an A14 block? |
From Forsby Finland
Hi Will, yes you can use the A15 head straight on the A14 block, without any clerarance problems!! I have only raised the compression by using flattop pistons so I don
Posted on: 2004/1/23 6:21
I am building a mean Datsun E10 racer  , a15 turbocharged engine, aiming for 280hp....
From GOLD COAST AUZ
Thats one of the first thinks i do to my A14 blocks, thay fit on BUT look on the side of head to manifold for water holes.If you have a water manifold it goes on if you dont you must block the holes.3 of 4mm holes.
Posted on: 2004/1/23 11:00
rather be a old fart than a young d##khead
Registered Users Contentmaster Usermaster
There is a little info about milling in the newly updated article A-type Cylinder Heads.
Posted on: 2004/1/24 4:33
