« 1 (2)
Re: Master Pump Problem
From Perth
Picture shows piston at bottom
Those seals look right way around
Other piston the 2 seals close together are supposed to be opposite each other... hard to tell by pic
The one closest to end has lip pointing back up the bore oppositre to all the others
SO 4 face down the bore... and the one faces up
Put the bottom piston in and push it down with a screwdriver and hold it all the way down the bore
Then fit small screw that stops the piston coming back too far
Then release the screwdriver and the piston pops back and stops on the pin
Then refit top piston and circlip
Posted on: 2011/2/18 10:59
From Sri Lanka
Hi dattoman_1000
do you mean piston with the 2 seals closer has to face each other ?
thanks
regards
sumith
Posted on: 2011/2/18 11:08
From Perth
Yup. thats what I mean
Posted on: 2011/2/20 3:40
« 1 (2)
