Browsing this Thread:
1 Anonymous Users
A15 racing pistons |
Not too shy to talk
Hi!
I am starting to build new race engine my racer, but here in finland pistons are were diffult to find. Does anybody have some wiseco order number or tips any pistons what i can use?
Posted on: 2011/2/27 13:56
Re: A15 racing pistons |
Registered Users Contentmaster Usermaster
For wiseco they are not a stock item. They are a custom item, about $100 USD each. You specify the type you want (flattops, dome tops, etc).
Posted on: 2011/2/27 20:04
Not too shy to talk
Another car pistons useful?
Posted on: 2011/2/28 10:48
Yes, some guys fit Justy pistons, but they need top be machined to fit and the block machined too.
Posted on: 2011/3/1 3:36
Not too shy to talk
Can you tell me more those justy piston? It make easier to ask those pistons. thanks.
Posted on: 2011/3/6 7:10
I haven't done it myself, but it was discussed in 78mm 1567cc pistons
Posted on: 2011/3/6 7:19
Quite a regular
From Olympia, WA, USA
From the Datsun1200.com Classified Forum - Posted on March 3rd by PJZ. ===============================================================
FS: NEW 76mm JE Forged race pistons & USED 74mm Venolia In the shop I found the following Datsun 1200/A-series race pistons:
(6) NEW 76mm J&E forged, wedge dome A-15 race pistons. $USD 350 + shipping. NOTE 1: Only have NEW rings, pins and clips for ONE PISTON. You will have to source the others. Easy, as they are common rings. NOTE 2: These were made by J&E with a 0.300" wedge dome, then 5 of the 6 had the dome machined down. You need to machine the 6th to match. NOTE 3: These are made with a shorter compression height for the A-15. They can also be used in the other A-series engines.
(7) USED 74mm Venolia, forged wedge dome A-13/A-14 race pistons, with pins, used rings and used teflon buttons. $USD 100 + shipping.
Peter Email is best. PeterZekert (at) Juno.com
Posted on: 2011/3/7 5:18
"Horsepower... May you always have enough"
