Dynoed my SR20DET today
From Little Rock, AR
Just thought I'd share. I dynoed my 180SX today, it's in metrics so I'm not too familiar with how it transfers over to horsepower and ft./lbs torque anyway here's what it did:
183.5 PS at the wheels @6633 rpm
24.2 kgm torque? @5532 rpm
Stock boost...max .54 kg/cm
One thing that seemed odd to me is that it didn't get near full boost until about 4600 rpm which seems pretty high to me, i.e. lots of turbo lag (I don't have a boost guage in the car yet).
The car is an automatic and totally stock besides the following: a Blitz air filter, HKS outlet pipe, Jet Hot coated header, Test pipe (no cat), and 3 inch exhaust system. This engine was going to make it's way into my 1200 coupe, but I'm picking up another SR20 to go in instead. I wonder how the 1200 would run with that much power?!! I was overtaking, but about even with a Skyline GTS-T that runs 14.2 in the quarter mile. I could see easy 13's in the 1200...not bad. What you guys think?
-Andy
Posted on: 2004/1/27 9:04
Re: Dynoed my SR20DET today
From Warwick, QLD
IF I had a Skyline that did a 14.2 Quarter maile I'd be pretty disappointed with it.
But anyway tell us how the conversion goes. all the best.
Damo
Posted on: 2004/1/27 10:40
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Sydney, Australia
The turbo lag could be the turbo "choking up" with solidified oil junk, from not letting it cool down after driving hard. A good roller bearing turbo will fix this.
A healthy SR20DET will get you mid 12s in a 1200. Get:
a 3 inch mandrel exhaust
a 3 inch Cat convertor
A big intercooler (don't chop up the front to make it fit)
up the boost to 12psi
You can expect up to 230ps (270ps with roller bearing) at the wheels with this combination.
Posted on: 2004/1/27 12:48
PS is the european HP rating. 183 HP (136 kw) is not bad at alll ...
Not sure what kgm is ... but the torque is probably close to or a little less than 183 lb. ft (HP = lb. ft. torque @ 5252 rpm).
Posted on: 2004/1/27 16:31
From California
Shoey, cats are not required on older vehicles here, are you suggesting he uses one anyway?
Also, if twistex's n.a. ka24e Coupe does high 12's, shouldn't a healthy sr20det 1200 do that much better?
Posted on: 2004/1/28 3:13
The turbo seemed to be in great shape when I pulled it off a few weeks ago. The car only has 72,000 km on it and it had a turbo timer on it when I bought it. All the fluids were beautifully clean too. I agree that a roller bearing turbo will fix the lag...that's for sure! My brother is selling me his S15 turbine (T28 roller bearing) for my car, he's putting down about 250 hp at the wheels with it. Yeah I already got the 3 inch mandrel exhaust and no cat (test pipe), just need to get an intercooler kit, boost controller and fuel controller (SAFC) and the horsepower would jump considerably.
I'm not really let down by the dyno run at all. With that automatic and stock everything besides exhaust and air filter I think it's exactly where it should be. I plan on doing another dyno run after swapping out to the 5 speed manual. I've always wanted to see what kind of difference it makes. Sometime after Feb. 14th I'll do the swap and dyno run. I'm going home to the US (finally!) for a couple weeks and I'll get to work on and drive my Buick which I miss a lot. Nothing else compares to over 500 ft/lbs of torque starting below 3000 rpm! Can't wait to feel that power again!
-Andy
Posted on: 2004/1/28 3:14
Twistex's KA24E is high-13s, I think.
13's with a 2-liter is nice, low boost even so. Does 5-lbs of boost beat a 20% larger engine? Probably makes the two about even.
Posted on: 2004/1/28 3:30
i have a 1200 ute, a14 stocko. i dont think it would go over 60mph, let alone do under 14seconds lol
Posted on: 2004/2/10 10:39
yep its nice
i wanna get extractors twin webbers and 6x9's and a new head unit wooo and a new gearbox and diff
Posted on: 2004/2/10 10:41
i wonder what my ute would dyno
Posted on: 2004/2/10 10:43
