« 1 (2)
Re: Anyone have/using a DREMEL tool? Wanna buy one
From Perth WA AUS
Nice tip Wurzel, I'll try that.
Posted on: 2011/3/4 8:40
Datsun 1200 2Dr sedan.
yeah good one dave- now all your usual part supplier will charge more cause of the possible demand from nige. pfft.
Posted on: 2011/3/4 9:05
From mandurah
ive got a cheapo GMC one and it works great i used it to taek my brazed together linkages apart ,by cutting away at the join ,i did this so my linkage rod didnt get damaged by the oxy
also ive used it with a little wire wheel to clean carby parts ,when removing old gaskets ,i lightly bued of any left over gasket instead of using a paint scraper
ide by a cheap one and if it breaks buy a better one ,no need to spend hundreds of dollars on a tool that wont get used all day everyday
good luck !
Posted on: 2011/3/4 14:30
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
« 1 (2)
