saab 9000 intercooler f/s
From Brisbane
I have a saab-9000 blackstone intercooler for sale. The saab 9000 used the garrett T25 turbo (i think) with a 2.0 petrol engine. The core measures 22" x 26" x 1.5" (inch). Although huge, I fitted it to my 1200 quite easily, the lower section slipping between the chassis and apron. It was a just a bit restrictive with the CA18T, but I believe it would be perfect for an A12 turbo set up, especially a circuit car due to its large surface area.
Really only looking for 25 bucks. Can post, I'm in Brisbane. Any takers?
jpg  Saab intercooler.JPG (158.25 KB)
1333_4d71b0241b1ce.jpg 1024X392 px
jpg  Saab 9000 intercooler.JPG (180.45 KB)
1333_4d71b17648a10.jpg 850X511 px
Posted on: 2011/3/5 3:44
Re: saab 9000 intercooler f/s
How much to post to Melbourne 3805??
Posted on: 2011/3/5 22:22
Car free
As in restrictive you mean chokes the ca18 a tad? as the
ca18de is 1.5cm longer than an A series with the same style
of single front pulley.
Posted on: 2011/3/5 22:44
That's a slim unit, how did it perform?
Posted on: 2011/3/6 4:37
From Brisbane
Hi there,
post package dimensions would be 90cm x 50cm x 6cm. Weight is 2-3 kg. Therefore to 3805 is around 17 bucks - allow for 20.
Yes it was slightly restrictive with the airflow. Mind you I had a T25 roller-bearing turbo giving a lot more air than standard T25. An A12 turbo set up should be fine.
The blackstone units are known for there efficiency in cooling air- all aluminium and very light with plastic end tanks.
Posted on: 2011/3/6 20:36
