« 1 ... 5 6 7 (8) 9 10 »
Re: Lightweight CA18 - need your input from CA18 freaks
with the amount of work required to fill in
the sohc ca20e chambers i might as well just
durafix fill the ports to at least improve
angles and shape and make a tap for the inlet
spark-plug and clean up the bump.
Unless I can get a 4 spark head from O/S
Posted on: 2011/3/6 22:08
the eight-plug heads (NAPS-X) got 46 mpg in the T11 Stanza. Wouldn't you want this most-efficent version?
The rwd transmissions are $81 here.
Posted on: 2011/3/7 3:29
From Sydney NSW
Fit a CA to the car first then muck around. There is a probably a lot more than just engine mounts to deal with.
Posted on: 2011/3/7 4:22
DD is that a 63 series CA box?
46mpg is very appealing!
CA20E compared to NAPS-Z Z20E is narrower, shorter, 77 lbs (35kg) lighter!
Here is what Im going to use to re-shape the ports
http://www.youtube.com/watch?v=N-cv3R ... feature=player_detailpage
Wet sleeving A CA would be nice down the track for a zx14 head conversion :)
http://www.youtube.com/watch?v=SIgq2R ... feature=player_detailpage
Posted on: 2011/3/7 5:11
Edited by D on 2011/3/7 5:26:51
Edited by D on 2011/3/7 7:26:01
Edited by D on 2011/3/7 7:26:54
unfortunately we only got only one RWD car here with CA engine - the S12 silvia "240SX" with either CA20E or CA18ET
* FS571B transmission 5-speed 1083-0186
* FS571C transmission 5-speed 0186-
Posted on: 2011/3/7 8:10
so the early stanza didnt get them either :(
Oh well at least I can get a 5 speed for the ca.
Im also thinking of buying some xz12r or zx14r
pistons for the build once the head is sorted
Posted on: 2011/3/7 9:46
Edited by D on 2011/3/7 10:08:53
http://www.norrisdesigns.com/proddetail.asp?prod=S13%2D014004
400aud for a full knife edged ca18de/t crank is a good deal
anyone going and coming back from England? :)
All cranks have counterweights which are generally very slab sided. this causes a slowing effect when they are forced through all the oil and gases in the sump at high engine revs. To alleviate this restriction we sharpen the edges of the counterweights to a virtual knife-edge. which allows a much easier passage through the sump at high revs. This makes the engine much smoother and dynamic increasing rev-ability and engine longevity. The front pulley and clutch cover are also part of the rotating assembly with the crank. when these are balanced they spin much more truly giving a smoother engine. An out of balance engine shortens life expectancy and gives a harsh feeling when revving hard. If the donor crankshaft needs grinding then this is charged as an extra amount on top of the price shown. This product is exchange. Email Friend Price: £254.47
Posted on: 2011/3/9 1:42
Block choices ca16de vs ca18de
Here is the head that Im using a ca20e thats had about 250 grams removed and shaved
to make way for the other 250grams to be added. I will clean smooth it up later.
jpg  ca20eshaved.JPG (192.18 KB)
737_4da016c81a046.jpg 757X573 px
jpg  ca20eshaved1.JPG (197.92 KB)
737_4da016d6f35cb.jpg 730X602 px
Posted on: 2011/4/8 12:24
Edited by D on 2011/4/9 9:20:41
Edited by D on 2011/4/9 9:21:18
Block choice of CA16 would be lighter weight wouldn't it? Then bore it out to take CA18 pistons.
Posted on: 2011/4/9 2:21
Yes I thought the same but the ca16 has more meat in
the bore walls to be taken out to ca18 specs.
I didnt get the photo posted it didnt work here goes again
the idea is to fit the ca16de block with either bigger bores
or offset sleeved for z22 or other 87mm pistons.
Either 1809cc or extra 1988cc with stock stroke.
Also can anyone help me with tensioner info?
Im going from the twin cam to sohc
det block, ca20e head
is the green circle below all I need for the sohc conversion?
It has a tap or part of a bolt in it, I will have to tap out.
jpg  ca18deblock.JPG (195.29 KB)
737_4d9fc3c3ad15f.jpg 739X465 px
jpg  tensioner ca18.JPG (194.27 KB)
737_4d9fe87935d6a.jpg 624X709 px
Posted on: 2011/4/9 3:22
Edited by D on 2011/4/9 6:03:00
