« 1 2 (3) 4 »
Re: time for new brake pads... what do you guys suggest? (road/race)
From Melbourne Vic
fair point, it;d pay to read threads like this
temp rating for a1rm is 780 i think bendix is somewhere around 500?
a good pad and fluid combo is essential (i use lucas rbf600)
i have cooked my fluid at sandown which cosequently burst the rear cylinders which left me with 0 brakes at the end of the back straight!
Posted on: 2011/3/12 4:57
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Melbourne AUS
i havent had any problems with fluid boiling either... its actually been really good for brakes
like i said its the first pad change in a few years..
maybe its the light weight 1200..... or maybe im not driving it hard enough!
Posted on: 2011/3/12 6:01
1973 B110 A12
From Sydney,NSW
In my experience it doesn't take long at all to get up to temp. Always fine within half a lap of wakefield.
Maybe with the answers, people are trying to keep it simple, If the bendix worked, try the next step up (QFM's), but dont go crazy, one step at a time
Id say doing a complete flush of the fluid and replacing with good fluid is a really great idea while your at it.
Posted on: 2011/3/12 9:21
From brisbane
ANGE wrote:
im running the standard s13 caliper on the 250mm vented disc
and so far the ute is still willing to go deeper under brakes than the driver
i think i'll try the qfm's..... keen to hear mattys experience with them
Back from QR and I'm not overly impressed with the QFM pads. The "feel" wasn't as good as the Intimas and I experienced massive vibrations as the pads got hot. Having said that it could be as simple as me not bedding them in properly. They didn't come with instructions so I bedded them in the same way as I have always done. The track was wet today too so that may not have helped things.
I much prefer the Intimas and will be refitting them tomorrow. I have never had a fade issue with them and they give very good feel. I do change them once they reach half worn as I have had a set start to crack around the edges previously once they got below halfway.
FWIW I used to use Motul RBF600 and never had any fade or boiling issues with it. I have since changed to Penrite Sin as it is significantly cheaper with no degradation in performance.
Ange - I know a number of people who swear by QFM A1RM pads hence why I am wondering if it is a bedding in issue. Up to you mate. They are cheap enough to try and see what happens. I have listed an Ebay link to the type of Intimas I use although they aren't the correct size.
http://cgi.ebay.com.au/INTIMA-BRAKE-P ... ories&hash=item25616a0792
Posted on: 2011/3/12 9:34
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From brisbane
Ange I pulled the A1RM pads out on the weekend and sent some photos off to Greg from GSL Rallysport.
It appears that, in my case, there has been a pad/rotor interaction issue due to me not having the rotors machined before fitment of the pads.
I have refitted the Intimas and will hang onto the A1RMs for when I next replace the rotors.
As always Greg was very helpful.
Regards Matty
Posted on: 2011/3/21 1:53
From Melbourne AUS
i wondered if that might be the case.... thanks for the feedback
is it becuase the intimas leave a layer of pad material on the disc? or just becuase they wont bed in on a used disc?
i dont plan on machining my discs this time round so maybe i'll stick with the bendix pad i have
ill have to pull them out and get the part number off them.. ive got a hunch they might be ultimates though...
Posted on: 2011/3/21 5:59
1973 B110 A12
From brisbane
Greg explained that the A1RM is known as a transfer pad meaning that it transfers itself onto the rotor. The Intima pad material remaining on the rotors was preventing this.
Posted on: 2011/3/21 10:52
From Perth
Have you determined your pad shape yet ?
Cause if its small caliper to suit 250mm disc Bendix don't make Ultimates in that shape
So thats not what you have
Maybe find out what your actually using so you have a baseline for suggestion
Posted on: 2011/3/21 11:38
From Melbourne AUS
ok so im running bendix db1117. im not sure if thats an ultimate series pad or not?
i tried looking it up but it seems bendix have changed their range of pads to
'street road track' and 'race', which i cant find any feedback or availability info on...
Posted on: 2011/3/30 8:37
1973 B110 A12
get a set of each and try them on the day. surely you will be allowed to change pads between sessions.
road, track sounds like the old ultimates.
Posted on: 2011/3/30 8:52
« 1 2 (3) 4 »
