PCV pipe???
From Sydney NSW
where does this pipe connect to? has it got something to do with the emissions or am i in the complete wrong area??
jpg  2.JPG (136.67 KB)
12278_4d8426ba02df1.jpg 1296X968 px
Posted on: 2011/3/19 3:45
Re: PCV pipe???
From Coondle, WA Australia
Can you give some more details?
what car, engine, which side of engine bay, what it connects to at the other end.
From the photo it looks like its a crank case breather pipe, and if so you can just connect it to the carby frypan, or you can just put a small filter on it and leave it at that, but some more detials will confirm that.
Cheers
Posted on: 2011/3/19 4:06
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: PCV pipe???
Typically connects to a PCV valve located just below the carburetor platform on the inlet manifold. Leaving that pipe as it is (to emit to atmosphere) can result in a defect, unless of course it is the A10 which simply vents to atmosphere. Is it an A14 btw?
It is to do with emissions, yes. The pipe carries the crank case fumes and directs them back into the combustion cycle so they are burnt and subsequently turned into exhaust fumes. There is a second pipe that goes from the rocker cover to the underside of the air cleaner, after the air cleaner element, you could put a T piece in and share it into that feed but you might as well connect it back to the manifold.
Posted on: 2011/3/19 4:10
Re: PCV pipe???
From Gawler, Sth Aust
I have been defected for that. I picked up one of these pipes from a 120Y at my local u pull it.
Any one ever replace their PCV?
Posted on: 2011/3/19 6:20
72 B110 A14
71 B110 A12a (Parts)
06 380 VRX
Re: PCV pipe???
Replace the valve? Yeah the spring in side can get a little worn sometimes.
Positive Crankcase Ventilation.
Posted on: 2011/3/19 6:28
Re: PCV pipe???
From Sydney NSW
reuby_tuesday- sorry mate, yea its in a 1200 ute its an A14 and the pipe is on the passenger side near the firewall. I think it is the crankcase vent from what i could find just didnt know what to do with it now that im running twin carbies?
clyons8-thanks mate made things a bit more clear, its my first datsun so in the learning process! so what happens with the outlet in the rocker cover aswell then? can i put a small filter on each of these or do they need to be connected to something?
cheers
Posted on: 2011/3/20 6:16
Re: PCV pipe???
yes put a filter on both of them will work
Not legal for street use
Race cars use a vapor separator
Posted on: 2011/3/20 7:10
Re: PCV pipe???
From Sydney NSW
thanks ddgonzal, whats the legal alternative so i can get it registered with no hassles?
Posted on: 2011/3/20 7:56
Re: PCV pipe???
Use a manifold that has provision for the PCV valve.
Some twin sidey manifolds do, most don't...
Posted on: 2011/3/20 8:06
Re: PCV pipe???
So it is an A14, not a bad eye eh?
There is no legal alternative apart from plumbing it back through the induction.
Most people pass the engine as suited to the guidelines and then modify or refit their add-ons later(once they've passed the inspection).
If you are running a downdraft weber most aftermarket air cleaner assemblies will accommodate a PCV return/feed, yet the assemblies are an exposed air-filter element that could also be picked up as a breach.
Tell us a bit more about what setup you are running and we can offer better advice?
With sidies you can plumb the whole lot in back through an induction plenum or air box.
Posted on: 2011/3/20 8:34
