What Lsd options for H165??
From Sydney,NSW
Just after options on what LSD centers are available for H165 (ute?) diffs? It has to be a mechanical center, for race use only...
Also, what rear discs to people fit to the H165's? Has anyone fitted R31 discs?
I currently have a hilux diff, locked center with R31 discs, looking to save some weight!
Posted on: 2011/3/24 9:36
Re: What Lsd options for H165??
From Gold Coast, Australia
Posted on: 2011/3/24 9:39
From Sydney,NSW
Now thats what im talking about! A few questions??
Is it available in a 1.5 way?
Can you post or pm a price?
Is it easy to come past 4.8ish gears for h165?
What about disc conversions? R31?
Posted on: 2011/3/24 9:50
From Sydney
Hey Andrew, I'd stick with the hilux setup with the power you're running, you'll bust plenty of axles in a h165, which are getting hard to find now, if you are interested though I'm running r31's on the back of mine so you can come have a look if you want, if you don't need a hand brake you can run commodore rear calipers.
Cheers Drew
Posted on: 2011/3/24 10:38
chooie you have a PM.
Posted on: 2011/3/24 11:16
From Melbourne, Australia
bluebird disc over drums bolt up, need to change over backing plates with a press though (change wheel bearing)
Posted on: 2011/3/24 11:29
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Townsville, Qld
my mate has a Kaaz 1.5 in a 165 center with ute 4.1 ratio. There was also some machining involved as he pointed out the pinion gears' unique new shape
Posted on: 2011/3/28 4:43
