82 bluebird parts on2 my 1200 ute
From Innisfail nth queensland
just got given a 82 bluebird with a l20b and auto that i will be putting in my ute what other parts can i use? any help would b great thanx
Posted on: 2011/4/14 11:42
help me iv got a 1200 ute after sum1 in north queensland with datsun parts
Re: 82 bluebird parts on2 my 1200 ute
From Townsville, Qld
the H165 diff center can be used if yours also has a H165, the axels are longer so if you wanted a spare set you'd have to get them shortened or just offer them up on aussiebluebirds.com. Also you could use the struts and brakes if you don't mind modding them a little to fit up though R31 struts are shorter which sorts out one issue you'd have with it.
Posted on: 2011/4/16 1:07
From Nations Capital, Australia
What ratio does the Bluebird h165 have?
Posted on: 2011/4/16 8:17
how do i tell what ratio i tell what ratio it is
Posted on: 2011/4/16 11:21
To identify the diff ratio, look under the bonnet:
It will say "HC" (H165) and a two digit number.
For example HC41 is 4.11 gears, and HC37 is 3.7 ratio
This will tell you the original diff for the car, but someone could have changed it.
Posted on: 2011/4/17 0:58
