Browsing this Thread:
1 Anonymous Users
HELP!! L18, B310, Stanza 5 speed, H165 What tailshaft? |
Not too shy to talk
From Wagga Wagga, NSW
ok so the story is that i need to get a tailshaft for my sunny and i keep getting told different things. L18, stanza cross member, stanza 5 speed, stanza h165 HELP ME!!
Posted on: 2011/4/15 11:25
Re: HELP!! L18, B310, Stanza 5 speed, H165 What tailshaft? |
From Armidale N.S.W
We made suggestions on Ozdat and also mentioned if you can give me some measurements from box input to diff flange. we can check the tail shafts i have for L series and H165 setup. H150 is the same diff flange to that widens the options.
Posted on: 2011/4/15 11:51
71 1200 Sedan A12 cruiser build 73 1200 wagon SOLD 76 1200 Ute CA18DE And Stumpy box SOLD.
Registered Users Contentmaster Usermaster
The stock B310 auto tailshaft is 1045 mm (u-joint to u-joint). * The B310 manual tailshaft won't fit the L-series transmission. * The B310 auto tailshaft I believe will fit the A10 transmission, it's the right length and has the correct slip yoke for A10 manual or auto transmission. See Propeller Shaft Swaps
Posted on: 2011/4/16 1:30
From Geelong, Vic
would the stanza tailshaft not be the one to use? arent stanzas and sunnys pretty much the same body? so if you use all stanza stuff it should work right?
or are stanzas longer?
Posted on: 2011/4/16 4:40
From Geelong, Vic
how did that double post....it told me it was an invalid submission
i was getting that too ... "invalid submission", may be a site problem which will clear up tomorrow.
Posted on: 2011/4/16 6:25
i am getting that too ... "invalid submission", may be a site problem which will clear up tomorrow.
Posted on: 2011/4/16 6:27
