« 1 (2)
Re: Burning Oil
From MELBOURNE
It smokes all of the time but more after its been idling. I gota tell you is pretty bad.
Posted on: 2011/4/19 4:23
Re: Burning Oil
By "blue" smoke people mean white smoke with a slightly bluish tinge -- that's a sign of oil burning. Pure white smoke is normal when warming up the car on a cold day.
worn valve guides typically will not cause smoke while running the engine, but rather a small or large puff on starting the engine. If it blows blue smoke while driving this is usually worn piston rings . Do a wet & dry compression test to make sure.
It could be caused by other things, even an overfilled crankcase. The A-series only takes 3 litres of oil.
Posted on: 2011/4/19 5:43
Re: Burning Oil
From mandurah
Sometimes if it only blowa a little bit of smoke ,you can put a slightly thicked oil in to stop it from blowing smoke
But eventually you will need to put a set of rings in the motor
Posted on: 2011/4/19 6:58
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: Burning Oil
Another relevant question. Auto or manual? What suburb are you from?
Posted on: 2011/4/19 10:16
« 1 (2)
