(1) 2 3 »
need some help brake pads wearing out in a month
Not too shy to talk
I have a 1976 1200 ute which had i dunno if they were standard or not but it had a disc front end, anyway dad used to drive it and it never wore out pads, it sat in the shed for 10 years or so then we took it out and did it up rebuilt everything painted it etc put a 1400 motor in it, anyway dad drove it down from out house in new south wales down here to tassie everything was fine, had it on the road down here for about a month was driving heard a grinding noise the outside left pad was worn out to metal, replaced the pads they lasted about a month, found out there was a crack in the rotor which explains it, got hot opened the crack and wore the pads out.
so what i did was went down to the local wreckers they had a 120y which was owned by an old lady that didnt thrash it lol
i got the calipres and rotors out of it, put them in my ute the rotors look pretty new no cracks or wear marks, put an ew set of brake pads in and they wore out in about a month and a half again, i do have a tiny leak in my brake system somewhere i have to top up one of the bottles in the master cylinder from half way or so to full about every 2 weeks,
does anyone have any idea why my pads are wearing out so quick? its really giving me the #OOPS#s big time
Posted on: 2011/4/20 10:39
Re: need some help brake pads wearing out in a month
Sounds like they are engaged when you aren't pressing the pedal? Ever so slightly.
Posted on: 2011/4/20 10:43
Not too shy to talk
could be, how do i fix that mate?
it does brake very well also
Posted on: 2011/4/20 10:44
From vic
could the front caliper pistons be seized or sticking riding on the rotor?? rebuild could solve it as im not sure any other reason why it would go in a month unless its some chinese pads
and never use those feredo or what ever its called there rubbish they were worn out in a few weeks and dust all over my wheels just used it coz they ran out of bendix thats all i recomend you use!
Posted on: 2011/4/20 10:46
Not too shy to talk
yeah the ones i got were like $22 off carpartsnmore.com.au i think
i got a brand this time called premier with a year warranty on them, i cant get bendix they dont make them anymore :/
Posted on: 2011/4/20 10:49
From Melbourne, Australia
The first assumption would be sticky pistons in the calipers but very unlikely to be the same problem in two sets!
Next will be either a blockage in a brake hose. Sometimes they perish inside and act like a one way valve. If the problem is in one wheel predominantly then pull that hose off and check iternally.
Lastly if that's not it then it will almost definately be the master cylinder. $20 will get you a rebuild kit and a bottle of brake fluid. Easy job to do. Good luck!
Posted on: 2011/4/20 10:51
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Not too shy to talk
the left wheel wears out quicker then the right yeah but only just, alright mate i might have to go try this cheers
Posted on: 2011/4/20 10:58
From vic
also you were saying theres brake fluid leak if theres air gotten into the system it could cause sticking of the pistons!
Posted on: 2011/4/20 10:59
From Perth
Bendix don't make what ?
Pads... err... someones misinformed you
Posted on: 2011/4/20 11:04
Not too shy to talk
i couldnt get db 39's from repco, autobahn, super cheap or bursons lol
can anyone link me to somewhere i can get them online?
yeah im gonna find out where the leak is tomorrow
Posted on: 2011/4/20 11:07
(1) 2 3 »
