Perth boys
Quite a regular
From Perth,thornlie
Hey Perth boys were do any of you'd recommend I send my a12 for full race spec rebuild and to source some carbs to suit ???
Posted on: 2011/4/22 3:07
Re: Perth boys
From mandurah
Southside engine center for a rebuild but ide get rid of the a12 and built an a15 like I am
Carbs ,you can buy of recarb and they are on a manifold and jetted to suit your motor
Neither are cheap but youll kick yourself if you do it on the cheap like I did with my a12
Now im building a hot a15 and using twins ,should go heaps better than my 12 did
Posted on: 2011/4/22 5:57
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: Perth boys
Quite a regular
From Perth,thornlie
If I was to go a bigger engine I'd prob go with an a14 as the a15 does not rev as hard as the a12 or a14 how much are u spending on your a15 including carbs
Posted on: 2011/4/22 7:39
'79 1200 ute 13b project build
Re: Perth boys
Quite a regular
From Perth,thornlie
And they couldn't really sell u a carb pre jetted for your engine for most precise tuning you would have to dyno tune
Posted on: 2011/4/22 7:43
Re: Perth boys
From Freo
a 15 is easier to find, and there's no substitute fro Cubic inches.... the rpm difference from 14 to 15 is negligable..
Posted on: 2011/4/22 7:52
A15 PSI Project Motor
'72 CB750k,
Re: Perth boys
Quite a regular
From Perth,thornlie
Were would I pick my self up an a15 and wat are the the best carbs to run for maximum power ... What are the power out puts for a12 and for a15 both race spec built ??? Just a roughy
Posted on: 2011/4/22 8:15
Re: Perth boys
From Perth WA AUS
A12 I'm not sure, A15 you should get at least 160hp with a race spec motor.
Mine is supposedly built for 160hp ATFW and its not full race.
Posted on: 2011/4/22 8:43
Datsun 1200 2Dr sedan.
Re: Perth boys
From Perth
What sort of racecar are you building ?
Posted on: 2011/4/22 10:48
Re: Perth boys
Quite a regular
From Perth,thornlie
160hp not bad. Not a racecar just a weekend cruiser I have a 1200 ute that my father and I are restoring ATM that I bought off my uncle he bought it brand new in 79 and it's nearly ready for a motor was going to go with 1200 but looks like I might have to go with a 1500 so pretty much just a really nice street car to get out On the weekends for fun
Posted on: 2011/4/22 11:32
Re: Perth boys
From mandurah
Sounds nice !
I mean they sell them roughly jetted to get it running then from there dyno tune it :)
But yes a15 are heaaps better than a12 nothing wrong with an a12 just not as good as an a15 or 14
Should be a good little cruizer when done by the sound of things
Posted on: 2011/4/22 12:27
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
