bracing needed when cutting out tunnel??
quick question guys, is any type of structual bracing required when cutting out and changing the tunnel on and 1200 ute. dont want it to twist or bend. Ute's completely bare shell.
any advice appreciated
cheers
rob
Posted on: 2011/4/25 15:57
Re: bracing needed when cutting out tunnel??
From mandurah
Firstly what motor and box are you going to run ?
Also have you chopped the tunnel out ?
Posted on: 2011/4/25 16:23
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
ca18det ca gear box, havent cut the tunnel out yet. the whole motor gearbox tunnel im using was already in a 1200 ute im just tranfering it into my ute
cheers
Posted on: 2011/4/25 16:30
From mandurah
You dont need to chop the tunnel of a 1200 ute when using a ca18de ,iys a tighter fit but its doable ,just need to massage the tunnel near the seat rails
Its abit too much work realy just for abit of extra room around the box
Posted on: 2011/4/25 16:42
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
fair enough thanks mate, still wanting to change the tunnel to the one i have ready to go in my concern was if i need to brace the cab/floor before i cut the old one out?
Posted on: 2011/4/26 3:39
From Everywhere, mostly Melb/Geelong/Ballarat
Always good practice to brace the floor when doing a chop like that. The windscreen in my coupe cracked when I cut my tunnel so since then I have always braced. A ute you can probably get away with it but why risk it for the sake of saving a few tack welds? :)
Posted on: 2011/4/26 4:07
