what diff 2 use withL20B and auto
From Innisfail nth queensland
im putting a L20B with auto in2 my 1200 ute will the original diff handle it or should i just go 5speed to save canging trans tunnel etc what diff does my ute have its am85 model all the running gear cost me nothing with a whole bluebird thats thats i was gunna stick with tha auto its onl gunna b a cruizer no race car but it will b driving long distances
Posted on: 2011/5/5 9:33
help me iv got a 1200 ute after sum1 in north queensland with datsun parts
Re: what diff 2 use withL20B and auto
From Armidale N.S.W
Will have H165 diff will handle it for a while just dont go to silly off the mark. Change ya tunnel mate its less friggin around in the long run even if you do go the 5 speed.
Posted on: 2011/5/5 11:19
73 1200 wagon SOLD
if its driving long distances what does it matter if its manual or auto. once at cruising speed, on the freeway, you tend not to change gear and down shifting from 5th to 4th for hills would be welcome rather than a 4 speed kick down to 3rd or 2nd on a auto.
Posted on: 2011/5/5 11:28
what tunnel i have a 120y 1 and a bluebird 1
Posted on: 2011/5/5 11:33
120y one should do for manual trans but the auto may need a little more room.
120y seems to be the easiet to mate to the 1200 floorpan. not sure on bluey one.
Posted on: 2011/5/5 11:34
i no the bluebird is 1 big sucker
Posted on: 2011/5/5 11:41
which would be the best tunnel u know of for a auto conversion
Posted on: 2011/5/5 11:42
From Geelong, Vic
should be able to fit the auto in a 120y tunnel, pretty sure they use the same auto as a 120y anyway
think i looked at the bluebird one for my sedan and decided against it for some reason, but 120y is the best one to use i've found
Posted on: 2011/5/5 12:29
thanx bud
Posted on: 2011/5/5 13:31
ute diff is strong enough. even nissan put the H165 behind L20B.
Best tunnel is B110 automatic. Then B210. They both fit the largest Datsun transmissions.
Posted on: 2011/5/5 19:57
