« 1 (2)
Re: a12 turbo
From Christchurch NZ
I was told that all garret/airesearch turbo's were carbon seaaled ootb.
When you start to get to the pointy end of the wedge, water/meth injection is your friend. Google search "aquamist" and you'll find the parts to build a kit at the right price. This will unlock lots or reliabilty/horsepower.
Posted on: 2011/5/15 5:59
Forced Induction!
Re: a12 turbo
That 25* your running is a bit retarded isnt it?
Im running a A12 on 22psi and I have my ignition locked at 25* however that is with water injection - I know water injection helps with knock but not so much it allows me to run nearly twice as much boost?
I also use 98RON. What fuel do you use josh?
Also the T25's have a carbon seal variant - I think all you need to convert it is the carbon seal rebuild kit.
Posted on: 2011/5/15 7:25
Re: a12 turbo
the early t25 came with a carbon seal from factory
nice build too good to see
Posted on: 2011/5/15 7:45
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
Re: a12 turbo
Not too shy to talk
From Sydney
Will the old set up be up for sale then?
Posted on: 2011/5/16 0:41
Re: a12 turbo
From Freo
there is deffinately a carbon seal conversion for the T25, I had mine done...
Posted on: 2011/5/16 1:03
A15 PSI Project Motor
'72 CB750k,
Re: a12 turbo
From mid north coast
i wasnt sure if the t25 was or was not so i just put it on.steve i was going to put the set up in the classifieds in a few weeks to help fund the new a15 set up.What do u guys think its worth?? it would have to sell it as a complete kit, braided lines,throttle linkage,dump pipe,brand new exhuast etc.
Posted on: 2011/5/17 10:40
Re: a12 turbo
From West syd
Soooo u selling this set up?
Posted on: 2012/2/13 7:48
« 1 (2)
