old-tin wrote:
I have always heard that a too big radiator will cause this. And if you have a 9 liter radiator when A12 stock is 4.5 liters, perhaps that is the problem. If your engine is running too cold
thats crap! if it was the case no outbord motors would ever get to operating temp(the ocean is as big a radiator as you can get) the thermostat is what controls rate of flow to the radiator and should not allow it to run cold if the appropriate temp rating is used.
remember that the biggest morris minor engine was a 1000cc and the datsun a-series was based on that design.
OK, firstly the Datsun engine has NOTHING in common with the Morris engine & even the most cursory comparison will reveal thet fact.
Secondly, it's the thermostat that controls the temperature of the coolant in the cylinder head.
There is NO back & forth flow in the lower radiator hose, the flow is simply a pump assisted thermo siphon principal.
Water that is cooled in the radiator decends while the water in the block & head is being heated & it rises. The pump keeps the flow going from cylinder head to radiator top tank, down through the core into the bottom tank, then into the lower hose, then into the block, then up to the head, past the thermostat & round & round she goes.
The thermostat restricts the rate of this flow & even redirects it back into the block to ensure quick warmups. The radiator can be from a Mack truck & it would make no difference to the engine.
The cool water from the radiator that is passed into the engine is exactly the same volume as the heated water that the thermostat allows out of the head & the temperature balance is well regulated when the thermostat is of the proper rating & is working properly.
As for the rough running, well that quite possibly has nothing to do with the coolant temp.
Most 1200's use an exhaust heated inlet manifold. It heats a small area of the inlet manifold directly under the carb & any fuel droplets that are too big to make the 90 degree turn in the manifold will hit the floor of the inlet manifold under the carb. This is the bit that is heated remember.
This liquid fuel is quickly turned to fuel vapour by the heat & drawn into the engine to be burned.
It must be remembered that it is only the fuel vapour that burns in the combustion chamber, fuel in liquid form does not burn & is passed out the back as "unburned hydrocarbons"
Lets add some extractors. Now we no longer have a source of heat to vaporise the fuel in the manifold.
The carb mixes the fuel & air in the right proportions but a significant percentage of this fuel is now passing through the engine unburned, which means that the remaining burnable fuel [vapour] is much less than it should be & the combustion chambers see a lean mixture.
Result? Power is down, & since more throttle is needed to restore power, fuel consumption goes up while driveability goes to hell.
See? Aren't extractors a wonderful thing on an otherwise stock engine?
This is why manufacturers switched to water heated manifolds. A much larger section of the inlet manifold can be heated & to a much more controlled degree.
The exhaust manifold can also be designed for better flow without he need for flapper valves etc.
So in winter, standard road going cars with carburettors need MANIFOLD HEAT to overcome the two refrigeration effects that occur at the base of the carb [on the inside] these being
1. Latent heat of evaporation. [huge heat is extracted from the air & fuel at the point of conversion from liquid to gas]
2. Temperature drop at the point of pressure drop. [this happens just under the throttle butterfly where atmospheric pressure is on one side of the butterfly while manifold vacuum is on the underside of the butterfly]
These two principals can be demonstrated by
1. soaking ones hand in petrol on a cold windy day, then hold it up in the wind. Brrrrr
2. Pump up your home air compressor to full pressure & allow the temperature [of the compressed air] to cool down to atmospheric temp, thn open the drain cock & watch the ice form on it as the air passes from high pressure to atmospheric pressure.
Exactly the same principal.
How do we fix these?
1. Fit a serviceable thermostat, new or used, genuine or not, just as long as it is serviceable.
2. Heat the bloody inlet manifold. It matters not how you do it but refitting the standard exhaust manifold would be a good start.
Smoother running, better driveability, more power & improved fuel economy should result.
Now you know why later cars had a hot air inlet system on the air cleaner too & they worked a treat.
Covering the lower half of the radiator will mean that the air passing through the core will be heated more & it's this hotter air that is being sucked into the carb that will provide vetter vaporisation & a small improvement in performance.
I did this with my 1200 ute many years ago & in sub zero air it was an advantage.
Damn clever those Datsun engineers, a damn sight smarter than most of us yet we keep ignoring their wisdom & we keep getting it wrong.
My dead stock 1200 Coupe starts first time even when the car is encrusted with morning ice. I just let it run at about 1000 rpm for a few minutes to let it get the chill out of its bones & with the heater on the ice on the windscreen quickly melts away.
By the time I can see clearly we are good to go & full performance is available after only a few miles.
Gotta love those Datsuns.
