1200 ute engine swap
Does anyone know if i need to modify my standard cross member to put in a L18 or can i get away with the standard one or will i have to get a new one made all together??
Posted on: 2011/5/28 5:28
Re: 1200 ute engine swap
From Gold Coast
<<< a quick search over here will net you all your answers mate. I believe this topic was explained again a few weeks ago
Posted on: 2011/5/28 7:15
You can either modify the crossmember (the traditional method)
or modify the engine brackets, and leave the crossmember alone.
Depending on the oil pan you use, the crossmember need no modification. Otherwise people mod either the pan or the xmember.
There are many ways to do it.
Posted on: 2011/5/28 9:28
From Geelong, Vic
an L series will not bolt to the stock crossmember...something will need to be modified
Posted on: 2011/5/28 9:59
thanks heaps for your replies,
the guy i bought it off had it in a 1200 but when i asked him if the cross member had been modified, he was under the impression it was a completely different cross member, but i am not sure if he was correct, it may sound dumb but is there anyway of telling if the engine mounts have been modified??
Posted on: 2011/5/30 7:30
Yes, just compare them to the stock engine mounts. There were basically two types
More photos at Engine Mounts
Posted on: 2011/5/30 7:42
no worries mate, ill have a look. Thanks heaps your a champion
Posted on: 2011/5/31 9:53
