310 5 speed question
From Los Angeles,CA
Anyone know a source for rebuild parts for a B310 5 speed. Bearings, syncros, bushings,seals, etc...?
Posted on: 2011/6/4 10:30
Re: 310 5 speed question
You can still get synchro's through nissan, and most bearings aftermarket. The only bearing I couldn't get aftermarket was the 18 24 17 between the input and output which is genuine only. I got energising clips lately, tried for lugs but they are on bacorder from Japan.
Posted on: 2011/6/4 10:42
Skf is 1/4 price of nissan. Same bearings, skf is genuine. See the wiki
Datsun 310 neva had 5spd. B310 did.
Posted on: 2011/6/5 1:12
From Los Angeles,CA
There's a part number breakdown for the 60L box in the tech wiki, but not for the 60A. How do I know what bearings to look for? Plus what about thrust washers, seals, any wear items.
Posted on: 2011/6/5 1:54
Seals are at the bearing supply company too. When you disassemble, read the number on the bearings and seals.
For synchros and washers, go Nissan. You can buy bearings and seals from Nissan too.
Posted on: 2011/6/5 2:17
Hi adam
I wont be at my parts catalogs until wednesday, I can look then
Does any one else here know?
Posted on: 2011/6/5 2:42
From Los Angeles,CA
Thanks David!......Quote:
ddgonzal wrote:
Hi adam
Posted on: 2011/6/5 2:47
From Vancouver, Wa
Adam, There is a place here in Portland, OR called all trans that supplies rebuild kits
http://alltransmission.com/
Posted on: 2011/6/5 6:38
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
From Los Angeles,CA
Thanks! Unfortunately they supply parts for every nissan trans EXCEPT the 60A 5 speed :(...........
Posted on: 2011/6/5 10:50
