Browsing this Thread:
1 Anonymous Users
Valve clearance & S/Plug preference |
From port elliot , SA
hey guys just setting hte valve clearances on the turbo A series and will 0.013 COLD & 0.014 HOT be ok or should i do them differently for turbo aplication ? and also what Spark plugs should i run ?
thanks casey
Posted on: 2011/6/6 6:31
Re: Valve clearance & S/Plug preference |
Registered Users Contentmaster Usermaster
The only reason to set valve non-stock is if you have a custom cam and do what they recommend.
For spark plugs, start with stockers and then examine them after running in the engine. If they show signs of overheating go colder heat range (see the owners manual for heat range).
Posted on: 2011/6/6 8:44
cheers dd cam is about GX spec i got it off someone and cant recall the degree
Posted on: 2011/6/6 9:26
From Ringwood, Melbourne, AUS
for a turbo car it might pay to run the exhaust clearances a little looser due to the extra heat they are going to see. Talk to a cam grinder, they should be able to give you some advice.
Posted on: 2011/6/6 13:19
Deano
