12A overbore
Quite a regular
Can anyone tell me what oversize pistons were available for the 12A. ie: .020";.030"; .040"; .060" ?
A further question on this subject.
How far can the 12A block be bored out? Will they take the 1400 size piston?
Posted on: 2011/6/19 23:47
Re: 12A overbore
From Perth
I believe an A12A +40 would use an A14 piston
Posted on: 2011/6/20 1:00
Re: 12A overbore
Quite a regular
Dattoman,
Thanks for interest and reply.
A standard 1200 piston is 73mm dia. A standard 1400 piston is 76 mm dia.
Fitting a +.040" piston from a standard 73mm does not yield a 76mm bore.
A piston of this size adds slightly over 1.0 mm. to the bore(74mm). That's quite a way from standard 1400 size.
Are you suggesting that the standard 1200 block can be bored out to 1400 size?
Posted on: 2011/6/20 1:51
Re: 12A overbore
From mandurah
Dattoman is talking about an A12a I think you have an a12 where the bore could be different
12a is a rotary ,a12 is our beloved datsun motor
Posted on: 2011/6/20 4:05
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: 12A overbore
Quite a regular
Must be a Freudian thing! I last had a 12 A rotor motor 22 years ago!
I think you get the gist of my query. I'm talking Datto , not the ZoomZoom brand!
Posted on: 2011/6/20 4:39
Re: 12A overbore
fredeuce, so are you talking about an A12 or an A12A? Stock bore is different for each.
Posted on: 2011/6/20 6:37
Re: 12A overbore
Quite a regular
The A12 is the one I'm referring to.
Posted on: 2011/6/20 8:58
Re: 12A overbore
From sydney.nsw
you can go 74.5mm bore +060(1.5mm)with no problems.i have some new std 040 or 060 pistons/rings if you interested. where r u located. cheers
Posted on: 2011/6/20 9:09
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: 12A overbore
Can anyone tell me what oversize pistons were available for the [A12]
Any oversize you want. You can order custom pistons from most performance piston manufacturers.
Nissan sells STD, 0.50 and 1.00 (.5 mm and 1 mm oversize).
Posted on: 2011/6/20 9:10
Re: 12A overbore
From Perth
A12A bore is 75mm... so I was right in that 40 thou gives you the A14 bore of 76 :)
Posted on: 2011/6/20 12:22
