Fuse Box Multiple Power Inputs
From Sydney, NSW
Hi Guys,
I want to put in a new fusebox.. I'm looking for one that has split circuits i.e. 6 blade panels for ign and 6 for batter or something..
just wondering if anyone could suggest one.. tried soldering wires to blade terminals on a blade box on the weekend but surely there is a better setup or a prefab one!
is there something like this available here? FUSE BOX
Cheers,
Tom
Posted on: 2011/6/21 3:36
Edited by thomen on 2011/6/21 4:12:54
Re: Fuse Box Multiple Power Inputs
Go to the wreckers and get a Pulsar N12 fuse box.
Posted on: 2011/6/21 4:27
From Sydney, NSW
do they have a split circuit setup?
any photos?
Posted on: 2011/6/21 4:31
Yes they are split circuit. So is the stock 1200 fuse box, but it's only [edit:] six fuses. Some newer Nissans have twelve fuses, rectangular blade.
Im using this Nissan 10-fuse box, split between IGN and Battery
Posted on: 2011/6/21 4:54
Edited by ddgonzal on 2011/6/21 7:37:13
From Sydney, NSW
nice! and did you have to change the plugs etc?
Thanks for the info!
Posted on: 2011/6/21 5:01
From Seattle ,WA.
I'm planning on adding a 2nd fuse block & ran across this - I thought it was pretty well laid out & liked the fact you can very easily change a circuit from switched to constant power. I also asked the mfg-er if one could ground the entire panel instead of having to run back each circuits grounds to the box & they said that was fine. I'll probably buy this & give it a shot..
http://www.fuzeblocks.com/
Posted on: 2011/6/21 5:34
From Sydney, NSW
Cheers EDP! looks great!
Posted on: 2011/6/21 5:39
From Las Vegas, NV USA
I used a fuse box from a 12 circuit used painless products harness we took out of a car that got wrecked. It fit gret in the stock location and gave ma some additional outputs for the EFI.
BTW this is probably the BEST forum for ANY Datsun/Nissan I have ever been on!! Great work!
Posted on: 2011/6/21 7:34
Check out Fuse Box
This is the one I was thinking about 16 fuse + spares. It is 1984 B11 Sunny/Sentra or maybe some other 1980s Nissan.
I dunno what connectors are on the back side, probably closer to stock than the aftermarket boxes. Either plug in or cut & solder.
Posted on: 2011/6/21 7:58
OK that is the B11 box, i found photo of the cover
it is actually an 18 fuse box.
It is split into three: BATTERY, IGN and ACCESSORY
jpg  24310-02A00_.jpg (51.16 KB)
174_4e00447a1914b.jpg 600X552 px
Posted on: 2011/6/21 8:14
