« 1 (2)
Re: My 1200 sedan club car. Selling unreg.
From Brisbane, Australia
Hi Dave,
the Corolla diff is from KE30-KE55 - they all look the same to me! But the one we use is an Aussie made BorgWarner diff fitted because of our local content/assemble laws in the 70's, so they probably won't be the same diff in the NZ Corollas.
In Aus they had 3.9, 4.1, and 4.3 ratios. They are about 3" wider housing - almost perfectly matches track after Stanza or similar strut swaps. Spring mounts line up OK on the 1200 springs. I won't go into too much detail because they're probably not available over there unfortunately.
Harry
Posted on: 2005/5/18 5:30
Thanks Harry,
I have a sneaking suspicion that the KE20 diff may be very close and perhaps some further investigation is warranted.
Failing that an H165...
Cheers
Dave
Posted on: 2005/5/18 5:46
From Adelaide, Australia
Hey guys, i have a ke10 it has a jap diff, same (different width) as the datsun1200 jap diff and centres are interchangeable, also ke20 is the same cause i have just put in a locked ke20 centre. i think the axle lengths vary between them all. You can also use a 120y jap diff centre. But i think they are all H145 diffs. Ke30 early is H145 jap, then some assembled in aus used the borgwarner diff mentioned here, i can measure centre of leaf to leafs for the different models for people if they wish. Ke20 an Ke10 are different stud pattern than the ke30 though. Ke30 and on same as datsun.
Sean
Posted on: 2005/5/18 9:56
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Hi Sean,
Do I read you correctly here when you say that the early Jap KE 30 diff head is H145? If so then they must be a straight bolt in to the 1200 housing?
Has anyone else heard of this? I guess that it is quite possible that the same Japanese manufacturer was used for both Toyota and datsun.
Cheers
Dave
Posted on: 2005/5/19 5:20
Pretty damn sure, just that a mate of mine said he used a 120y jap centre in his ke30, and i have used a ke20 jap diff in my ke10, so i guess toyota and nissan shared manufacturers for their components. For example i use 280zx struts in my ke10, they bolt up perfectly to ke20 steering arms, which just happen to bolt onto ke10 ball joints. I love japanese cars!
Posted on: 2005/5/19 10:11
IPRA Build
From Near Bundaberg QLD
Uhhh, didnt they both get made by Borg Warner like someone mentioned earlier......derp....
120Y's and KE's of around the same years used borgs (except for the 4 dr wagon which uses a H145 centre according to the one I pulled out from underneath the one at the wreckers). If you unbolt a plate to look at your gears you've more than likely got a borg. If you unbolt the carrier and axles to look at your gears, youve got a jap diff.
And it probably differs between jap assembled and aus assembled vehicles. Buggers me, if it bolts in it bolts in.
Posted on: 2011/6/21 13:42
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
120Y's used borgs (except for the 4 dr wagon which uses a H145 centre according to the one I pulled out from underneath the one at the wreckers). If you unbolt a plate to look at your gears you've more than likely got a borg. If you unbolt the carrier and axles to look at your gears, youve got a jap diff.
A bit late for a comeback. 6 years is a bit late.
Posted on: 2011/6/21 13:51
Yeah. It was a waste of time, as I could've just put this in:
http://datsun1200.com/modules/mediawi ... php?title=Rear_Axle_Swaps
Posted on: 2011/6/21 13:59
And is a further waste of time since the info in the wiki came from this thread...I think I'll stop now LOL
Posted on: 2011/6/21 14:06
« 1 (2)
