« 1 2 3 4 (5) 6 »
Re: engine dies?
From vic
also could you just tell me what this jet is and does mine has size 50 but a12 1 has 60 what would larger size achieve?
Thanks!
jpg  carb jet.jpg (99.26 KB)
14954_4e082060c47bc.jpg 1152X648 px
Posted on: 2011/6/27 7:18
Re: engine dies?
That is the power valve. The size is usually not a worry.
The primary is the one closest to the center of the engine. Sounds like your carb had the jets installed incorrectly.
Posted on: 2011/6/27 7:38
Re: engine dies?
From vic
yer i think it was wrong size to do you think from size 101 to 136 is too big for primary will it cause my engine oil to be washed off in the cylinder?
do you know were i can get hitachi jets from maybe i should try 1 or 2 sizes smaller?
Thanks for your help dd!
Posted on: 2011/6/27 8:11
Re: engine dies?
I think that size is good if it drives good. 101 is too small from the way it was driving.
It all depends on how the carburetor is designed. They may use un-flowed jets, and the air jets may be a different size. Main jet alone means nothing without the air jet combination.
It the china carburetor intended to use genuine Hitachi jets? You can get them from your old carburetor.
Posted on: 2011/6/27 8:15
Re: engine dies?
From vic
i found this website they have solex main jets i think it might be the same as our hitachi jets what do you think?
http://vwparts.aircooled.net/Solex-Ka ... r-Main-Jets-p/fssj002.htm
i have size 136 in thier now should i go down to like 127.5 or 130 or lower? (125)
Thanks!
Posted on: 2011/6/27 8:27
Re: engine dies?
I think not. Each carburetor company has their own way of rating jet sizes. Further, some flow-test the jets then stamp them (accurate) but others just stamp them without actually testing (less precise where both a 128 and a 130 might actually work the same).
So a Solex #125 might be the same as a Hitachi #130 or maybe even a Holley #120 -- who knows? Nominally the numbers indicate the diameter of the drilled hole, but hole shape and design can have a huge effect on the actual flow.
First, get the carburetor running well. Don't worry about it being overrich, unless that causes it to run poorly. As stated, A15 jets are fine for A12 engine.
Finally, after you get it running well, you can then fine tune it by using different size jet. That's your last step. I would suggest trying the jets out of your old A12 carburetor to see if they are an improvement over the jets in the new carburetor. Remember to swap both the air jets and main jets. They work in combination.
Posted on: 2011/6/27 22:23
Re: engine dies?
From vic
hi thanks yer the car runs fine now with the 136 jet in the primary main. i got this from my old carb secondary main, as the primary size 96 made it worse!
do you know were i might be able to get some hitachi jets so i can fine tune it?
Thanks!
Posted on: 2011/6/28 3:25
Re: engine dies?
Fine tune it using the air bleeds, instead of the jet. See what that does.
You can order the jets and air bleeds from Nissan.
Posted on: 2011/6/28 4:21
Re: engine dies?
From vic
hi is the one circled in black the air bleed for primary jet its a size 70 at the moment should i increase or decrease the size if i have increased the primary main jet? (i opened this jet and its a long tube with holes like a emulsion jet) is this it??
also the one in red under the cap is a jet to i think for air do i change that too?
Thanks i will try nissan any idea what the model is of the carb on a a15 dch306 or dcf306??
Thanks!
gif  carb air bleed.gif (167.45 KB)
14954_4e094e60eb6ed.gif 922X519 px
Posted on: 2011/6/28 4:45
Re: engine dies?
Good to hear you sorted it out.
Posted on: 2011/6/28 4:51
« 1 2 3 4 (5) 6 »
