maddat ca18det firewall clearance
From Sydney
hey guys has anyone got any info from the swaps on the measuments from the firewall? ive heard that the maddat crossmembers are not more than 1 inch from the from the firewall, is this true and enginners want more that 10mm/1 inch away all round?
any help is great
Posted on: 2011/7/2 23:44
Re: maddat ca18det firewall clearance
1" is 25mm, mine was less than that around the 15mm mark from the back of the head to the firewall. if you move it to far forward you'll have problems mounting your thermo fans i would assume
Posted on: 2011/7/2 23:48
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
Some will sign off on 20mm, but depending on engine mounts, most get 1 inch from what ive seen
Posted on: 2011/7/2 23:58
Quite a regular
i have a maddat one
and its barely 10mm off the firewall, i had scott from maddat come out and he assured me that this is passable by engineers, ideally id prefer another 10 mm but i guess ill wait and see
Posted on: 2011/7/3 0:16
gathering bog dust in the "DATCAVE"-
1200 coupe a14 quad carbd dished wats daily project
1200 ute ca18det,minitubs,irs,flared,ssr mrk3 dished jdm custom project
1600 sedan l18 supercharged mrk 2s, fender mirrord daily
mazda b1800 pickup v6 bike h...
From Melbourne, Australia
My engineer told me the legal spacing between engine and any fixed part in the engine bay is 10mm.
Posted on: 2011/7/3 0:23
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
From Gold Coast
Shoota is on the money there, the legal clearance for rego is 10mm+ that's all mine had when I had the ca in there
Posted on: 2011/7/3 0:39
From Melbourne AUS
1/2 inch is a good guide, basically if you cant stick your finger in the gap, its too close
Posted on: 2011/7/3 1:21
1973 B110 A12
this is something that is very clearly written in the guidelines for engineering. must have 10mm clearance to everything and no brake lines near exhaust/turbos
Posted on: 2011/7/3 2:03
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
ok... i had a custom cross member, now im changing to maddat... struggling to get the motor in, it seems like motor will be about 10mm off the firewall....
problem is there is a solid and a flexible water line that need to go across the back of the motor, plus the 1200 heater hose exits the firewall behind the motor, all these things are 15mm thick (except the solid line but that is mounted 15mm off the motor).... 15mm hoses in a 10mm gap isn't going to happen...
so how are people getting motors in with heaters and such all hooked up?
Posted on: 2011/9/18 6:40
1200 Coupe Rallycar
Mad Dat tunnels or drilling holes maybe?
I really think electric heaters are the go in a non daily now - just for demisting
Posted on: 2011/9/18 7:58
