« 1 (2)
Re: clutch mod
From Sydney
I used a remote s2 oil cooler it mounts under your oil filter much better option due to hoses n more mounting required
Posted on: 2011/7/5 8:54
Re: clutch mod
From sydney
ok sweet as thanks for that
Posted on: 2011/7/5 8:58
Re: clutch mod
From Melbourne AUS
to fit the master cylinder you need to just drill the required holes in the firewall and adapt a pushrod to your
clutch pedal. i think i made one to suit it from memory
i used a factory water to oil cooler from a series 3 rx7, save heaps of space and they work well
enough for n/a engines at least
Posted on: 2011/7/6 7:53
1973 B110 A12
Re: clutch mod
factory water to oil cooler from a series 3 rx7, save heaps of space and they work well enough
Yes, this is the best kind, keeps your oil cool, but warm enough to do the job. As long as your engine coolant system is working properly, the oil temp won't go too low.
Works good for a turbo engine too.
Posted on: 2011/7/6 20:46
Re: clutch mod
From Gold Coast
sorry for the hijack, but what master has been used that is the most compact? i have limited space behind my inlet manifold (ill measure today) and would like the smallest one that will do the job
Posted on: 2011/7/6 22:02
« 1 (2)
