« 1 (2)
Re: electronic igntion wanted
Datgx, you can also use the Pertronix Ignitor kit (i tink it's #1741).
http://datsun1200.com/modules/myalbum/photo.php?lid=245
Posted on: 2011/7/12 2:47
thanks mate but ild rather the elec dizzy anyone got one or a n12 one?
Posted on: 2011/7/15 12:02
datsun a15 ute
I have an electronic dizzy, will sell for $125 USD free shipping 6-8 days to Australia.
It is the one I had in my 1200 before I put the crank-trigger ignition on it. Both the bearing plate and vacuum advance are confirmed to be good.
Includes rotor & cap. Suitable for any A-series engine, both old & new. Use with original 1200 coil & resistor or (better) source a 12V coil from a newer Nissan.
Posted on: 2011/7/15 22:12
From Near Bundaberg QLD
Crane XR700 electronic ignition kit FTW!! All instructions included for fitment onto your standard points dizzy, just unscrew your points, pull your rotor off, put the trigger wheel and LED/LDR sensor over the shaft, put your rotor back on, screw the LED/LDR sensor in where the points used to be, hook up the 3 wires like the instructions say, DONE. My A15 has had it done. Only mods it has are extractors and a downdraft weber carb, and it stays level beside my mate's v8 bombadore in 6th gear when we both floor it (at least from 80kmh to 115kmh). You'll be surprised how much extra power you get with elec ignition.
Posted on: 2011/7/17 13:18
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
sounds like this is a really good mod for a 1200....almost a must-do.
Posted on: 2011/7/17 13:52
Or just fit a new set of points and adjust correctly will make just as much power. But with electronic ignition you won't need to replace and adjust every year.
Posted on: 2011/7/17 22:47
$125usd shipped to your door is a good deal datgx.
Thats 117-120 aud roughly by paypal. Will cost you
more time finding a good N12 dizzie that might have
shafts worn or other issues.
Posted on: 2011/7/18 10:40
« 1 (2)
