steering box ?
From sunshine coast
hey guys im looking for an exploded view of a b110 sterring box..i have been through the tech wiki but i need one showing all the parts ...any help is good help ..thanks
Posted on: 2011/7/15 3:54
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
Re: steering box ?
Posted on: 2011/7/15 6:40
Re: steering box ?
From sunshine coast
Thanks heaps ....I would be able to make her steer agin now :P
Posted on: 2011/7/15 6:58
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
Re: steering box ?
From Christchurch NZ
I;ve had a steering box query for ages.
Where the adjustor screw contacts the back of the sector shaft, what is used where the two parts touch? Does it have like a nylon rubbing block or what?
I only ask cos when I built my car, I wound that screw in a very long way. It tightened up my steering heaps! and made the car really positive to steer. But once it's out of adjustment, is that the end of the steering box? I have my doubts about the teeth inside it being bale to wear enough for it to have needed as much adjustment as it took. And I was surmising that perhaps it's more a case of whatever is between the screw and the sector shaft wearing instead.
In the exploded drawing, it doesn't name that part. And I figure my question is relevent to this thread.
Posted on: 2011/7/15 23:19
Forced Induction!
Re: steering box ?
Nope, there's nothing in between. The adjustor screw just meshes the two gears. When it wears out you throw the box away. But they last a long time as long as you don't overtighten the adjuster (it needs a tiny bit o' slack).
Posted on: 2011/7/16 0:20
Re: steering box ?
From sunshine coast
Thanks for your help I put it together today...new seals and stuff ...very smothe now Haha ..
Posted on: 2011/7/17 8:45
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
Re: steering box ?
When I rebuilt mine I noticed that when adjusted right, the steering arm would be snug in the centre but off to the left or right it would wiggle with play, my guess was that feedback into the steering wheel around corners would wear the rack unevenly - more than the centre (because the centre part is only used on straight roads)?
Posted on: 2011/7/17 9:40
Re: steering box ?
so if I make a longer screw, it can keep on adjusting the steering box forever?
Posted on: 2011/7/17 10:21
Forced Induction!
Re: steering box ?
Yes. Although t some point the sector & worm will be worn down and so you won't be able to turn it past the center easily.
Posted on: 2011/7/17 22:55
