replacement alternators
From Coondle, WA Australia
I wanna replace my alternator in the ole 1000, with an internal reg unit so as to tidy up the engine bay a little.
I saw the pics with an ea alternator change, and some spoke about a camery unit.
Just wondering what is a simple and viaable option would be. Is there a unit that I can swap straight in from a later model datto that has an internal reg?
Posted on: 2004/2/16 7:37
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: replacement alternators
From Perth, Australia
My 78 120Y has an internal Reg so yes, they are available....
it also depends on what electrical accessories you want to include... big stereo, driving lights, etc
Posted on: 2004/2/16 7:41
1974 120Y Coupe
40 thou overbored A14
32/36 DGV Weber
5 Speed Gearbox
New Interior (in the making)
My website
hmm about elecs, well I was running a pair of 100w spotties for extra light as the original lights have about 5 candlepower!
I also plan to install a reasonable stereo, nbothing stomping, just reasonable (ie splits, 4" fields, sub, 2 amps). So I am guessing that about a 55amp will do the trick. I wont be running injection or stuff like that. the old girl wouldnt know what to do with them!haha.
How many amps is the one on the 120y?
Posted on: 2004/2/16 7:58
From Perth W.A
i have a 55 amp alternator from a ford XF falcon 6cyl and it only cost me $20 i'd say that would do the trick i think the 120y ones were 30 amp
Posted on: 2004/2/16 8:50
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
cheers.
Was it a straight swap in, or did you have to make brackets etc.. I am chasing the simplest option, with about 55amp output. If the 120y is only 30 amp, then mine is about the same, so not much good.
I dont mind modding a bit, its just that My car is already stripped down, and I dont want to make unnessary work for myslef.
Posted on: 2004/2/16 10:18
From Perth W.A
i'm yet to do it but i don't think it would be much to swap.
Posted on: 2004/2/17 2:10
120y Coupe
From Melbourne, Australia
oops double
Posted on: 2004/2/17 3:03
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
in the time it took you to write those messages you could already have the EA falcon one on!!!
1200 Coupe Rallycar
From T'ville
i run a bosch with internal reg, v8 fairlane $30 ,had to make a mount!
ford v8 alt. have a big pulley which means that the axle speed is reduced, haven't cooked it yet,
keeping my fingers crossed
Posted on: 2004/2/17 13:22
i was looking at the wiring today, looks very simple to convert to internal reg, but i cant find my damn manual with wiring diargam, i think some wires that plug into the regulator on standard would need to be connected together, need the wirring diagrams to figure out which ones
Posted on: 2004/2/17 13:45
1200 Coupe Rallycar
