torque settings for inlet/exhaust manifold
From Sydney, NSW
Hi i know you have to work from the inside out when re-doing the manifold bolts..
but is there a recommended torque setting?
Also should it just be the gasket or is exhaust cement required as well?
Cheers,
tom
Posted on: 2011/7/18 5:44
Re: torque settings for inlet/exhaust manifold
Just the gasket plain with no sealer. Torque is 6.5 - 10 ft.lb. (0.9 - 1.4 kg-m).
Posted on: 2011/7/18 7:27
From Sydney, NSW
Wow.. you sure do know a heck of alot! thank you!!
Posted on: 2011/7/18 7:32
sealer is just when dodgey mechanics re-use the gasket
and limit your port areas with blobs of it.
Posted on: 2011/7/18 10:33
From Melbourne, Australia
re-torque after a couple of days, they always seem to loosen themselves after first use, never torqued them just done them quite tight with normal sized spanner... cant get torque wrench to most of them
Posted on: 2011/7/18 10:43
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney, NSW
Thanks for the advice guys! will give it a go over the weekend and let you know how i go!
Posted on: 2011/7/18 14:28
