Rings -- intall which side up?
Was looking at the Repco rings for A14 that I bought for $10 shipping included on eBay. Is the stepped ring the compression (top) ring, and go on the facting up? I think the other ring has a taper to it also.
Posted on: 2011/8/2 7:57
Re: Rings -- intall which side up?
From sydney.nsw
should have instructions in package.cheers
Posted on: 2011/8/2 8:03
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Maybe that's why they were so inexpensive -- no instructions.
Posted on: 2011/8/2 8:07
From sydney.nsw
ok, top ring will have inside bevel edge on inside of ring & faces up(or dot on ring facing up) 2rd ring with outer scraper edge faces down( or dot on ring faces up. if dots are casted in rings they allways face up. hope this helps cheers
don't forget to check ring gap
Posted on: 2011/8/2 8:18
From vic
the ridge on the ring faces up i think thats how i installed them when i did the rebuild i have a instruction paper i think for hasting rings if you need it!
Posted on: 2011/8/2 9:23
From sydney.nsw
instruction pic ( click on pic to enlarge)
jpg  IMGP0233.JPG (101.62 KB)
9764_4e37b56f5d0dc.jpg 730X548 px
Posted on: 2011/8/2 9:30
Thank you!
Posted on: 2011/8/3 4:36
