« 1 ... 12 13 14 (15) 16 17 18 ... 42 »
Re: 1200RallyCar - My road car rebuild - 1200 coupe
I need new lines, jeleaous of double flaring
Posted on: 2011/8/8 9:44
From SE Melbourne
double flaring kits on ebay are <$50....not like I can talk.
Nice job on the car Mike - see you on Sunday.
Posted on: 2011/8/8 12:05
Mildman, Datsunless
From Melbourne, Australia
grumble, couldnt drive it today, clutch and fuel pump issues
Posted on: 2011/8/8 13:21
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Nearly there. That'll give you some last minute stories to tell the grandchildren. That is assuming that the car doesn't over excite you to the point of testicle explosion.
Do you think you'll still make it?
Posted on: 2011/8/8 13:46
dunno, need to replace pump and bleed clutch, but there was some horrid thrust bearing type noises which have me worried
Posted on: 2011/8/8 13:55
1200 Coupe Rallycar
is the bearing noise from sitting too long unused, and then they sort of free up? i remeber my a series doing that.
Posted on: 2011/8/8 14:03
From Melbourne Vic
thrust bearing shmust bearing! good to see the old motor fired into life :D
what box are you using?
Posted on: 2011/8/8 17:59
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
yeah motor fired up like a charm!
using a skyline stumpy, will bleed clutch and take it for a drive and then yeah, fingers crossed the thrust noise goes away, there was no sign of it on the first day i got it going and drove it
ran the pump in reverse (wired backwards) for a little while before i figured out it was wrong, think thats buggered it, have to tap it with a hammer to get it to go so must be binding up
Posted on: 2011/8/8 23:51
1200 Coupe Rallycar
That's unfortunate. Get on to Mildman for a pump.
Posted on: 2011/8/9 11:40
just been past your house don, didnt hear the BOV? lol
Supafatto had a pump, chucked it in and bled the clutch and its all good now, noise disappeared after 30 secs
Its awesome again! been cruisin a bit all going really well, didnt get above 60 degrees so may have to put a switch on thermo and throttle cable a little short so idle is too high
lots of little bits to tidy up before cruise, but not all will get done
Posted on: 2011/8/9 12:06
1200 Coupe Rallycar
