Browsing this Thread:
1 Anonymous Users
Re: Estyres 1200 ute build thread V1.0 |
From Freo
Distance Skooling BigE... :) that stuff is expensive...
Posted on: 2011/8/12 5:29
'68 Thou Wagon,(home now) up and running '69 2 door project, the yellow thing, A12A Project motor, for the yellow thing. A15 PSI Project Motor '72 CB750k,
From Trinidad and tobago
3 angle valve job? What is that could you explain? Ikeep checking for updates mate.
Posted on: 2011/8/12 5:34
'71 Four Door Sedan. A15 Engine + Lighten Flywheel. E15 Electronic Ignition 32/36 Weber EI Coil 4 into 2 into 1 Extractors 1 3/4 Exhaust Pipe Semi Flow Hotdog 60 series Gearbox H150 Diff.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
From mandurah
It's the amount of angled faces on the valve seating area and valve seat
I think it just gives a better seal
Posted on: 2011/8/12 5:58
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
From sydney.nsw
Posted on: 2011/8/12 6:00
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From mandurah
Expert ^^
Posted on: 2011/8/12 6:08
From sydney.nsw
come on wheres the pic's.want to see, what one couldn't see over phone.( working blind )
Posted on: 2011/8/13 5:42
From Perth WA AUS
Yeah pics or ban!
Posted on: 2011/8/13 10:12
Datsun 1200 2Dr sedan.
From mandurah
ok so i have to thank ernie for all his help through out this build ,we have spend a few hours on the phone and he has beeen a huge help with this motor
anyone that can instruct me on how to dial a cam in ,over the phone is a legend !
now ,ive had 3 goes at trying to upload a huge spool on what i did ,and all the pics
i picked the motor up ,brought it home ,cleaned it up and got ready to paint it ,after i had done my piston to deck hieghts
next i painted the block and put all the bearing crank and pistons with rings in the block ,check the bearing clearances with plastigauge and then lubed up the journals and torqued it all down
next i dialed the cam in and did my piston to valve clearances again ,it all checked out so i then moved on to putting the head gasket and head on with the pushrods
next i painted up my rocker cover ,polished my timing cover ,and painted most the other bolt on bits
ok so the pics
Posted on: 2011/8/14 16:12
From mandurah
oh and i got stockers with hubcaps haha there soo small ,will be good burnout rims !
hhmmm 12 inch light truck tyres !
Posted on: 2011/8/14 16:15
From mandurah
oh and i bought new fuel lines ,old ones were $hit ,cost an arm and a leg but well worth it :D
Posted on: 2011/8/14 16:22
