Browsing this Thread:
1 Anonymous Users
Re: distributor install??? |
From perth
or stick your finger in the #1 plug hole turn engine till it choofs your finger off then you have the correct TDC (end of induction,beginning of power stroke) then turn by hand till TDC mark, (if its correct, outer ring of balancer can move on some engines, luckily not a series)
Posted on: 2011/8/12 10:54
From vic
thanks guys!
just out of curiosity i put the distributor in with the engine at 7 deg btdc on compression stroke what difference is it if i just put it in at 0 degrees at compression stroke?
Posted on: 2011/8/12 13:06
From Malaysia
i think your engine will backfire.
Posted on: 2011/8/12 16:37
Registered Users Contentmaster Usermaster
There won't be any difference. The engine will run without backfiring at 0 degrees BTDC. It just makes more power at 5-8 degrees.
And you don't have to pull the distributor out to set it to 7 degrees, just rotate it a bit.
Remember that dwell and timing are the foundation of engine tuning.
Posted on: 2011/8/12 22:38
From Malaysia
adjust dwell and timing before everything else, yes?
Posted on: 2011/8/12 23:19
Exactly right.
Posted on: 2011/8/12 23:25
