A15 Extractor Problems... Help!
From Melbourne yo.
Hey all, just wondering if anybody running an A15 in their 1200 has problems with extractors fouling on the idler arm? and if you dont have problems, what extractors are you running? any help appreciated! cheers!
Posted on: 2011/8/16 8:27
Re: A15 Extractor Problems... Help!
From Launceston, Tasmania
I'm running an A15 motor in my 120y with 4 into 1 extractors which I got new through an exhaust shop and dont have any issues with fowling on anything. Not sure about the 1200 model though.
Posted on: 2011/8/16 8:31
From Melbourne, Australia
Oxy torch, pipe up exhaust, bit of muscle, fixed!!
Seriously.
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
From Melbourne yo.
sweet as! how much did they charge for new extractors?
id give the oxy a go, but i dont have one, and also the fouling has dented one of the pipes in nearly a quarter of the way, so i think i might be up for some new ones...
after going down to the datto cruise on the weekend im amazed that you can fit in, and drive a ute! #OOPS# i struggle sometimes and im not that tall!!
any more help or suggestions appreciated!
Posted on: 2011/8/16 8:46
Will still flow ok- not great. I had some in ute, sedan, coupe, with a15 never an issue
Posted on: 2011/8/16 8:58
From Melbourne yo.
what sort of extractors did you run??
Posted on: 2011/8/16 9:08
just get a exhaust shop to heat it up and bend it in till it clears wont cost much and wont make a noticeable difference to sound or power
Posted on: 2011/8/16 9:19
datsun a15 ute
It is pretty common if you have a Ford or GM or Chrysler for these kind of clearance problems to occur -- heat and bend or heat & hammer is the usual solution.
A14 and A15 are identical as far as extractors go. Mine do not foul on the idler arm, they are EECustom extractors ex-Japan, designed for A12 for Datsun 1200 specifically, but I have them on an A14.
Here's an Aussie set that come close to the idler:
Posted on: 2011/8/17 5:15
From Ballarat Victoria
Another option is moving/slotting the engine mounts a touch. Even spacing one up a bit could help. Maybe try puting a jack with a block of wood under one edge(where the bolts go) of the sump to experiment before making spacers.
Worth a try if its close.
Posted on: 2011/8/17 5:51
VIC DYNO HIRE
