bonnet won't pop
From Melbourne, Australia
any tips on what goes wrong with the bonnet latch? cant get mine to pop
its definitely not the cable
ive adjusted the position of the latch on the bonnet to try to get it as central to the hole as possible
but i cant get it to pop on its own, need someone to pull it up at same time as pulling on the lever inside the car for it to unlock
so... which bit mucks up?
Posted on: 2011/8/16 9:32
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: bonnet won't pop
maybe the cable is worn and stretched
Posted on: 2011/8/16 9:43
datsun a15 ute
From Albury
Try adjusting the dick that hangs down from the bonnet inside the spring.
Sometimes a wee bit of lubrication will also help
If that doesn't work hit it with a hammer.
Cheers
Bob
Posted on: 2011/8/16 9:48
ah so the dick can be made longer? (serious question)
Posted on: 2011/8/16 12:53
1200 Coupe Rallycar
i saw mrs rally car playing with that on sunday didnt i????? on yours of course.
mine doest it some times. it had to do with alignment of the bonnet on mine. i sat it a bit further forward not in the moddle and it works. or was it back? away from the catch
Posted on: 2011/8/16 12:55
Yes, fresh grease helps. If it has old solidified grease that can sometimes cause it to stick.
But most likely the top piece needs to be unbolted and re-positioned as unfamilia found.
Nissan calls it the "male hood lock"
Posted on: 2011/8/17 5:08
so i spent another hour dicken around with it, and getting very angry but got there in the end
pops beautifull now.... who would have thought the female would have been to blame
was flogged out and miss-shapen
traded it in for a younger version i found under the house
Posted on: 2011/8/17 13:54
1200 Coupe Rallycar
Geez poor Claire, is she ok under the house now?
Posted on: 2011/8/17 22:30
