Starter problems????
From Secret Harbour WA
Hey guys been trying to start my ute for the last few days
put all the wiring in and tried to start it and nothing.
Starter doesn't make any noise thinking the starter it buggered or
needs a good clean. Has anyone had this problem before???
It's annoying me like crazy as I have tried two of my starter motors
and still nothing. Replaced battery. Now I just get a clicking noise but not from the starter
Help me please.........
Posted on: 2011/8/22 14:21
Re: Starter problems????
From Mandurah, Western Australia
Starter motor, connected to battery? Volts going to solenoid when cranking?
Even is starter rooted, will still get volts to solenoid and usually hear it click.
Posted on: 2011/8/22 14:41
Starter connected to battery with ignition wire connected to starter
starter doesn't crank engine starter is doing nothing but looking pretty
Posted on: 2011/8/22 15:01
76' B120 GX Style Ute
73' B110 coupe
75' Mini Van
77' Mini Van
71' R100 13B PP i miss it!!! its hiding in my garage in QLD
69' R100 GS Jap Spec
67' Mazda 1500 13b turbo
91' BMW e36 318
That wiring is a problem. The S wire should go to the starter, not the IGN wire.
The starter only needs 3 things, which you can measure with a voltmeter or test light:
* Earth/Ground. The Neg. battery cable should bolt directly to the engine.
* 12V supply. The Pos. battery cable should bolt directly to the starter.
* Starter wire.
Easiest way to test it is set the hand brake, put it in nuetral, reach down beside the engine and touch a screwdriver on the solenoid -- from the Pos. cable to the S terminal. If the starter, battery cables and battery are good it will crank.
Posted on: 2011/8/22 18:52
thanks for the info but that stuff wasn't the problem i worked it out today,
the wire on the starter motor that goes from starter to solnoid was on the wrong teminal
now kicks over and runs ....
Posted on: 2011/8/24 13:00
does it run well? nice going.
Posted on: 2011/8/24 13:01
Runs but sounds like #OOPS# straight out of the manifold
should have an exhaust on soon enough mik
Posted on: 2011/8/24 15:22
73' B110 coupe
75' Mini Van
77' Mini Van
91' BMW e36 318
Good to hear carps. Have you got a 120y wagon?
Posted on: 2011/8/26 12:45
hey old_school...
i dont have a 120y i have a 1200 wagon
but thinking about trying to fit 120y tail lights into it...
Posted on: 2011/8/28 8:11
Quite a regular
From Philippines
my starter was making this very loud noise when cranking the engine and it was really really loud my neighbor told me they were disturbed every morning since i go to work early. so yesterday i went to my mechanic and he told me to replace the bendix drive which i have no idea what it was, they put it back and to my amazement i can barely here the starter. it was really that silent. i'm really happy about it and my neighbor.
Posted on: 2011/8/31 6:02
1983 B120 A12
