Wagon rear 1/4 panel window question
From Schofields
Hi everyone, my wagon has brackets on each of the rear panel windows to hold a pole across the window.
I have seen an old brochure advert showing it, (see below) but doesnt say wat its for.
It says something about a parcel shelf but that high up in the windows? not likely
anyone have any ideas?
Posted on: 2011/8/26 10:42
Re: Wagon rear 1/4 panel window question
From Geelong, Vic
so that stuff in the back doesnt smash through the window when you take a corner fast
Posted on: 2011/8/26 10:46
From Schofields
i cropped the image to show the wagon for a closer view to see if it helps any!!
Posted on: 2011/8/26 10:51
From Geelong, Vic
that wasnt a joke, just like the utes have the metal bars running down the outside of the rear window
Posted on: 2011/8/26 10:56
From Schofields
i know your trying to take the piss BUT that said u could be right!!!
EDIT: just read your next post!
Posted on: 2011/8/26 10:57
From Schofields
i was considering putting little lace curtains on those rods!!! hahahahaha
Posted on: 2011/8/26 10:59
Pre emptying child tie down points for your kirstie. If they come with a sound proof buble like the homer- would be great
Posted on: 2011/8/26 11:01
From Schofields
it actually has got a mounting point in it, BUT my lil one is already in a booster seat and doesnt need a seat with a mounting point!!
Posted on: 2011/8/26 11:06
Didn't mean mounting point - meant you actually Tie them down when they get to be too much
Posted on: 2011/8/26 11:08
From Schofields
this is what the advert says:
1171 cc OHV 4-cylinder 69bhp (SAL) 5-bearing
crankshaft engine, 4-speed all synchromesh gearbox.
Front suspension independant strut type with
tension rods and stabilizer.
Rear suspension by semi-elliptic leaf springs.
Brakes are disc front, drum rear. Max speed 90mph.
0 to 60mph in 15 seconds. Minimum turning cirlce 26.9ft.
Standard equipment includes:
Padded instrument panel
Two-speed wipers
Electric screenwash
Heater and demister
Headlamp flasher
Parcel shelf
Glove locker
Steering lock
Cigar lighter
Rear seat folds flat to give approximately 50 cubic feet
of load carrying space with flat floor
Posted on: 2011/8/26 11:20
