Snapped nipple
From A-TOWN
So i was just about to bleed my rear drums on the ute and the nipple was seized and it snapped leaving the whole thread inside the drum which is #OOPS#ing gay cause i just paid for a permit to get the bastard registered.
Does anyone know the part number for this or know a place in Melbourne that will stock it?
Cheers,
Daniel
Posted on: 2011/9/1 9:23
Re: Snapped nipple
From Melbourne, Australia
probably easiest to buy a whole new slave cylinder that comes with one on it, then you don't have to try and get the broken one out
the nipple itself would be a very standard part and any auto shop should have it, or get one at wrecker or off the neighbour you don't likes car....
Posted on: 2011/9/1 9:46
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Snapped nipple
You really should treat them better
Posted on: 2011/9/1 10:04
Re: Snapped nipple
From MOOROODUC. Victoria
at least the guy in the photo seems to be enjoying his snapped nipple
Posted on: 2011/9/1 10:16
Re: Snapped nipple
From A-TOWN
should have added that i needed the rear wheel cylinder. Got a box full of nipples here.
Or......just thinking, i have a set of 1200 ute stock front drums, do they run the same cylinders??????
Ill have the hardest stiffy if this will work!
Re: Snapped nipple
probably a good chance... should have the bore size written on both, make sure they match. or maybe the wiki has the answer...
Posted on: 2011/9/1 10:19
1200 Coupe Rallycar
Re: Snapped nipple
From Bendigo, Victoria
I think from memory the front drums have two smaller wheel cylinders on either side.
Posted on: 2011/9/1 11:21
