Revised: 5 Speed Gearbox for sale
From Birchip, VIc , Australia
I have a 5 Speed 60L Dogleg Gearbox for sale. Overdrive 5th
Best Offer or Trade for a Celica 5 speed.
Rebuilt, Perfect Working Order.
Let me know if your interested.
Posted on: 2004/2/24 2:39
Re: 5 Speed Gearbox for sale
From Auckland, New Zealand
Close or standard ratio?
1:1 or over driven final drive?
How any kms since rebuild?
Posted on: 2004/2/24 5:00
From Auckland N.Z
hey Brent I also have a 60 dog leg box with a 1:1 final drive. $900? #### didnt know it was worth that much.
Posted on: 2004/2/24 11:24
Brent,
It's Standard Ratio. 1:1 Final drive and I wouldn't be able to tell you the amount of Km's as I bought it off someone else. I can't use the Gearbox as I've been advised that the torque in my new motor will just snap it.
Cheers
Posted on: 2004/2/24 22:02
Discostu,
Are you 100% its 1:1 final drive?
thanks
Brent
Posted on: 2004/2/25 0:45
Brent,
99% sure it is. I haven't even taken it out of the crate it came in when I bought it to have a look. If it is overdrive then you get a bonus. If you know of a way to assess whether it's overdrive or not, let me know and i'll open up the crate tonight at home to have a look.
Cheers,
Stu
Posted on: 2004/2/25 2:36
Stu,
I'm after one with the 1:1 final drive, overdrive boxes a easy to come by over here and is no good to me.
Other than turning the input shaft 5 times and making sure the output shaft turns 5 times, I don't know of any easy way of telling them apart.
If you take it out of the crate try not to break the crate as it'll be handy if I buy & ship to NZ.
thanks
Brent
Posted on: 2004/2/25 3:38
From Auckland N.Z
the 60A box IS the 1:1 final drive box. the 59A is the overdrive box. the 60A has a larger centre shaft and will handle more hp and is therefore more valuable.
Posted on: 2004/2/25 11:10
I have a 60a 5-speed. It definitely is overdrive, the revs are much lower in 5th than the original 4-speed in 4th. That does't mean there wasn't a direct-5th version available ... but for sure at least some 60a are overdrive.
What is a 59a transmission? The 56-series transmission was a direct-fifth design. It was standard in the GX-5 1200, and also available from Nissan Competition with "option 1", "option 2", etc gearsets.
Posted on: 2004/2/25 18:11
Brent,
I checked the box last night and to me it is 1:1 final Drive. I'm new to the mechanical world so tonight I'm going to get a mechanic that I know to come over and confirm the ratio. Tomorrow I'll have a definate answer for you.
Cheers,
Stu.
Posted on: 2004/2/25 22:25
