Distributor re-graph Ringwood?
From Melbourne, Australia
Gday,
need to see a specialist to regraph a dizzy, there is a notorious place in Ringwood somewhere i believe but not sure where/name
anyone know it?
Posted on: 2011/9/7 23:49
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Distributor re-graph Ringwood?
Ignition Torque in Bayswater is who I use.
8/78-80 Bayfield Road East
Bayswater VIC 3153
(03) 9720 6308
I've had them do every ignition that I've had, and he refuse's to let me spend money on things that are useless.
Posted on: 2011/9/7 23:54
From Ringwood, Melbourne, AUS
There is also these guys in Nunawading:
http://www.performanceignition.com.au
Unit 47, 41 - 49 Norcal Road
Nunawading 3131
Victoria Australia
Tel (03) 9872 3644
Fax (03) 9873 2646
No experience with them tho..
Posted on: 2011/9/8 2:05
Deano
From Freo
what specs do you give them???
might be worth posting dizzy's over...
Posted on: 2011/9/8 2:20
A15 PSI Project Motor
'72 CB750k,
I would say the place you are looking for is Performance Ignition (they produce the 'Scorcher' distributors that have been around for ages). Otherwise your could try ICE Ignitions in Cheltenham, who are highly regarded in the street machine scene.
Posted on: 2011/9/8 2:56
usually require idle timing amount and idle RPM, degrees max advance required and the RPM when you want the max advance all in by..
Posted on: 2011/9/8 2:57
Deano
From Melbourne,Australia
Ignition torque is the way to go. Jerry is very helpfull
Posted on: 2011/9/8 5:46
just been there, seems good
Posted on: 2011/9/8 6:19
1200 Coupe Rallycar
Were his torana's there? He's had the red one since I was a youngen.
Posted on: 2011/9/8 6:37
