(1) 2 3 »
new carburetor any good?
From vic
hi i was wandering if anyone here has bought this same carb and if they thought it was good or bad?
i know i have a bad experience with a chinese carb i bought but i need a new one and there only seems to be Chinese carbs!
http://www.ebay.com.au/itm/Datsun-120 ... m4aae652dd0#ht_558wt_1135
Thanks!
Posted on: 2011/9/10 10:37
Re: new carburetor any good?
I remember someone on this site saying they had used on with no problems just may need a fine tune!
Posted on: 2011/9/10 11:10
Car free
From vic
thanks i might have to give it ago and see how she drives with it hope its got more power than the one i have know at full throttle!
Thanks!
Posted on: 2011/9/10 11:17
You need to make sure when u push pedel to the floor the carbi opens fully as well! Should b ok I'd buy one as I wouldn't even try rebuild my own as to many small bits! Good luck
Posted on: 2011/9/10 11:21
Car free
From vic
thanks the only reason i need a new one is as my power valve is stick so it runs rich and power is horrible and just stalls!
sounds okay for $160
thanks!
Posted on: 2011/9/10 11:24
Good luck all the best
Posted on: 2011/9/10 11:28
Car free
Why not get a second hand Weber?
Posted on: 2011/9/10 13:15
From Malaysia
if i were you i would borrow a known good carburetor from a friend, to rectify, its 100 per cent carb problem. and yes, if its really carb that sucks, why not secondhand weber?
Posted on: 2011/9/10 13:42
From vic
how much better would it be than the stock hitachi would fuel economy be good and power?
i dont want to much stuffing around with the jetting to get it running right either!
also with the adaptor wont it cost alot?
Thanks!
From vic
hi i might consider a weber if i can find one thats got right jets for a a12 for cheap with the adapter for manifold
how much would they be roughly anyone selling one?
also whats the advantage over the stock hitachi?
Thanks!
Posted on: 2011/9/10 17:02
(1) 2 3 »
