Cam Specs for my new ISKY Race Cam
From Philadelphia, PA
INTAKE TIMING
DURATION: .310 deg
OPEN 49 before TDC
CLOSE 81 after TDC
CAM LIFT:.341
VALVE LIFT: .512
VALVE LASH: 028 hot
EXHAUST TIMING
DURATION: 310 degrees
OPEN 81 before TDC
CLOSE 49 after TDC
CAM LIFT: .341
VALVE LIFT: .512
VALVE LASH: .028 hot
Posted on: 2011/9/20 18:43
Re: Cam Specs for my new ISKY Race Cam
From Malaysia
your ride gonna be awesome :)
Posted on: 2011/9/21 1:44
Thanks ,,,,I sure hope so.
Posted on: 2011/9/21 2:07
From Las Vegas USA
Wow that's pretty aggressive ......similar to Motorsports Option 2 cam. What kind of compression ratio will you be running, I'm thinking that would need at least 12-1. Sounds like your car is going to be pretty roarty.
Tom
Posted on: 2011/9/23 4:50
