selling 32/34 carb ebay
From Far, far away
selling 32/34 carb on ebay
not needed.
Posted on: 2011/10/1 5:50
Re: selling 32/34 carb ebay
From vic
hi,
will this suit a a12 engine with an adapter plate? any idea what engine size it came off?
thanks!
Posted on: 2011/10/1 8:56
From vic
also how different would it be to the weber dgv 32/36?
thanks!
Posted on: 2011/10/1 9:00
From Far, far away
Looks like I'm advertising a carb, had no idea!?!
Sorry mate, that was just a dig at my wife. 32/34 is considerably different to 32/36, but certainly suitable to an A12. Check out the tech wiki, there is more info on each of the carbs. And yes, you will need an adapter plate.
EDIT: Just went through the wiki, struggling to find info on the 32/34 (I'm sure it's there though, positive I'd seen an article).
Posted on: 2011/10/1 13:07
From vic
haha no worries!
i looked on tech wiki and on the net but couldnt find any specs on it??
will it take same adapter plate as the 32/36 carbs?
Thanks!
Posted on: 2011/10/1 13:48
This is a weber ADM - Typically featured on the older ford falcon motors as a 34/34 ADM.
Probably the most common weber downdraught. For some reson datto peeps really dig the DGv/DGAV carbs but there are other webers out there that are just as good if not better.
The 32/36DCD is a great carb too but hard to find.
Posted on: 2011/10/1 13:54
Pretty sure fkange bolt pattern is the same. I'll be trying out one of these soon as well.
Posted on: 2011/10/1 13:56
Sorry I meant the Weber 28/36 DCD - economy and power.
This carb whorida is selling should be a good little unit. From what I remember they are quit squat as well which is a good thing for 1000 conversions (bonnet clearance with the bigger A14/15).
GL with the sale.
Posted on: 2011/10/1 14:00
From vic
would this carb provide better power than the stock hitachis the a12s have?
i thought this was a weber 32/34 DMTL??
thanks!
Posted on: 2011/10/1 14:04
Well yeah, the stock hitachis are a 26/28 aren't they? Or probably smaller. So the larger throats would help with the flow.
This is why the 28/36 DCD carb is such a great bore combo, small efficent primary bore with a very big secondary to back it up when the foot goes down.
Pretty certain it's a 34/34 ADM (not 32/34). I haven't seen a weber downdraught with two bores with such a small difference between the bores but the choke sleeves could have been changed over I guess. Search weber ADM on ebay or google. Never heard of a DTML.....
Posted on: 2011/10/1 14:08
