point getting burnt
From kenya,nairobi
what can I do to prevent the point of my dutsun 1200 from getting burnt most of the time?
Posted on: 2004/2/26 10:14
Re: point getting burnt
From Christchurch. NZ
Replace the condenser, or fit electronic distributor. .
check yout leads and plugs too.
Posted on: 2004/2/26 10:22
From GOLD COAST AUZ
Points run on 7.5 volts.A white block should be next to or on the coil mount,that has resistance wire in it.
Posted on: 2004/2/26 10:26
rather be a old fart than a young d##khead
From Brisbane Australia
The white block next to your coil is called the Ballest resistor this diplaces the heat from your points (well so the RACQ guy said)
I would drop in a new set of points,condensor and resistor.
Ade
Posted on: 2004/2/26 10:36
From GOLD COAST AUZ
R.A.C.Q and N.R.M.A are in the same boat,thay just call a tow truck.
N.R.M.A. means NOT REAL MACHANICS ANYWAY
Posted on: 2004/2/26 10:47
You think? Try getting a job with them as a field serviceman without qualifications.
Posted on: 2004/2/26 10:51
Love your Datsun.
Treat it well.
From GOLD COAST AUZ
WHY DO YOU THINK THAY CALL A TOW TRUCK. I know many tow operaters and some fieldmen good blokes and mates around the BBQ.WETEN each others boots.Thay call me to do deep recovery of stolen or dumped cars.Good money on the side.Towie gets his cut to.
Posted on: 2004/2/26 11:08
From GOLD COAST AUZ
OH NO we are of the subject of points.Thay burn because of to much power/volts.yYou only need to start on 12volts.
Posted on: 2004/2/26 12:08
From kenya,nairobi
thanks mate how do I solve this problem
Posted on: 2004/2/26 19:43
How to solve it?
If you don't have the ballast resistor connected, put back on.
Replace the condensor.
Posted on: 2004/2/27 5:32
