flywheel
From merimbula, NSW
hey guys, can i pick your brains?... rebuilding my 73' 1200 wagon with an A15 i got from a vanette. went to use the lighter flywheel from the original A12 but found it has stripped teeth, so, got the A15 flywheel and have found that it has only 2 locating dowels for the clutch?... shouldnt it have 3?, could one have broken off?... there is a mark where the 3rd dowel should be but its not there and dosnt look like its broken off?... any thoughts?...
And should i get the A15 flywheel lightened or keep it as is?... i will be running 70degree cam with a 32/36 weber.
thanks...
Posted on: 2011/11/7 2:14
Re: flywheel
From Tamworth , NSW
are you able to remove the ring gear off the flywheels and replace the a12 one with the a15 one.
might be cheaper/easier than getting the a15 flywheel lightened.
Posted on: 2011/11/7 3:46
Re: flywheel
From Melbourne, Australia
get another a12 one and turf the 2 you have
should be three dowels definitely, no need for a heavy van flywheel on your motor
Posted on: 2011/11/7 4:58
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: flywheel
From merimbula, NSW
ok thanks for the replys
Posted on: 2011/11/7 5:17
Re: flywheel
From Adelaide
You could put a new ring gear on the a12 one you have. Notch the old one, chisel it off and use an oxy torch (or a friends) to heat the new one and drop it on. Relatively easy job if you have heat.
Posted on: 2011/11/7 7:39
